03-13-2008, 17:48 | #1 (permalink) |
Junior Member Join Date: Mar 2008
Member: 725085 Status: Offline Thanks Meter: 2 | Nokia 6500C Charger not supported help..help şarz cihazı desteklenmiyor diyor bu sorunu çözemedim sorunu çözen arkadaşlardan yardımlarını bekliyorum PLS... şarz takılan bölümü tamemen degişti ve degişik şarz cihazlarında denendi sonuç yine aynı ! |
06-02-2008, 15:39 | #6 (permalink) |
Major Poster Join Date: Jul 2007 Location: Jedah
Member: 537833 Status: Offline Thanks Meter: 118 | 6500c Charger not support..plz Help us very urgent I changed the cable, charger and also AVILMA ....still its same. plz help |
The Following User Says Thank You to shanuani For This Useful Post: |
06-27-2008, 15:42 | #7 (permalink) |
Freak Poster Join Date: Apr 2004 Location: ilina Age: 44
Member: 62102 Status: Offline Thanks Meter: 167 | I have this problem too. Nokia 6500c "Charger not supported" I try other battery, other charger, flash in jaf, replace BETTY /N2300/ problem still.... |
The Following 3 Users Say Thank You to pepik For This Useful Post: |
08-01-2008, 21:25 | #12 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Uk (Birmingham)
Member: 719944 Status: Offline Thanks Meter: 2,117 | i have send send the post 3dayz b4...for same problam...but its solved now by me...just apply the jumper on fuse...i m sure ur problam will solve |
The Following 2 Users Say Thank You to chohansahib For This Useful Post: |
08-02-2008, 04:27 | #14 (permalink) |
Freak Poster Join Date: Sep 2007 Location: 1911 .45 (gubat sa syudad)
Member: 586346 Status: Offline Thanks Meter: 113 | i do but the unit is from wet unit... what i dis is clean the board or soaked the boad in the laquer thiner for 1 hr and brush the board every 5 min then dry it with moderate heat more air in hot air... and it work for your info only case to case basis |
08-02-2008, 07:12 | #15 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: I.N.D.I.A(PUNJAB)
Member: 309398 Status: Offline Sonork: 100.1590052 Thanks Meter: 5,455 | Quote:
nokia 6233 charger not supported please help me urgent | prakash40 | Nokia Hardware & Hardware Repair | 6 | 08-16-2010 08:54 |
nokia 7390 charger not supported help!!! | watari31 | Nokia Base Band 5 ( BB-5 ) | 3 | 04-22-2010 15:28 |
6500c charger not supported help urgent | classic mobiles | Nokia Hardware & Hardware Repair | 1 | 02-24-2010 17:24 |
plz help nokia 6085 charger not supported | smartengghelp | Nokia Hardware & Hardware Repair | 0 | 05-13-2008 11:00 |
nokia 6131 when charge show charger not supported.pls help | austinchan | Nokia Hardware & Hardware Repair | 2 | 01-17-2008 15:34 |
