Old 08-05-2010, 10:46   #1 (permalink)
Member: 1343713
Thanks Meter: 26
3110 contact service
a 3110 contact service here is mx key log plz guide m
Imei: 35318303691704
Restoring RF/BB DATA from backup ...
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 23F00117B4CC7E56D40E2A67A2C9E095F5C5A93E
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Erasing CMT NPC ... OK
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0581437)... OK
Updating PSN (MLH313206)... OK
Updating HWID (5008)... OK
Updating LOCK ...OK
Updating SUPERDONGLE_KEY ...OK
Updating CMLA_KEY...OK
Updating WMDRM_PD...OK
Certificate programmed successfully !
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35318303691704-2
Product Code: 0581437
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 353183036917042
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 27.107.16.248
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 08-05-2010, 10:50   #2 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 771
Write Good Pm File........
Old 08-05-2010, 11:13   #3 (permalink)
Member: 1343713
Thanks Meter: 26
bro. i tried a 3110 full pm if u hve any good & tested pm file then share with m
Old 08-05-2010, 11:17   #4 (permalink)
Member: 787710
Sonork: not using
Thanks Meter: 771
RapidShare: 1-CLICK Web hosting - Easy Filehosting
Click On Link.....
1> Repaire SD...
2> Update Sp lock....
Old 08-05-2010, 12:04   #5 (permalink)
Member: 1343713
Thanks Meter: 26
bro. same prob. set story is
set off in 3 min. super dongle key invalid then i save pm & rpl back up then all work i done 4 it but can't remove security test failed then i reset npc then errase then flash then write it's pm & rpl but set biling in nokia then full erase then flash write pm & write rpl but in this rpl some part r missing so copy another rpl then write set ok but same condition off in 3 min. then repair sd & other thing best but security test failed here i attached it's original rpl which save first time i think before m anyother person distrub it's rpl becoze by it set restart in nokia logo.
so anyone guide m
Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu
Old 08-05-2010, 12:15   #6 (permalink)
PedaLBoard's Avatar
Member: 1317565
Thanks Meter: 61
SIMLOCK_TEST passed
Load PM 1and309 only
before you write that
click super sd Auth. first then wait for the confirmation on server.
then click write.
thats it
Old 08-05-2010, 12:32   #7 (permalink)
Member: 1343713
Thanks Meter: 26
then click write.
thats it
bro. try super sd auth but so this error
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
Using cached productData[23F00117B4CC7E56D40E2A67A2C9E095F5C5A93E] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Old 08-05-2010, 12:40   #8 (permalink)
PedaLBoard's Avatar
Member: 1317565
Thanks Meter: 61
You are using mxkey old version
uninstall that old and download the new update of 3.4_rev1.2
try again after you install the new version 3.4_rev1.2
here is the 3110c_pm_1and309
Old 08-06-2010, 03:44   #9 (permalink)
Member: 1343713
Thanks Meter: 26
try with 3.4_rev1.2 but same prob.
Old 08-06-2010, 03:59   #10 (permalink)
Member: 1343713
Thanks Meter: 26
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Elapsed: 4.375 s (session timeout out after 3 second)
Old 08-06-2010, 09:00   #11 (permalink)
Member: 1343713
Thanks Meter: 26
anyone plz help m i done everything but same
Old 08-09-2010, 14:53   #12 (permalink)
Member: 1095582
Sonork: wats this
Thanks Meter: 2
use mx key write good pm connect super auther then write pm i try this solution 11000000% working
Old 02-19-2011, 13:01   #13 (permalink)
Member: 1519991
Question Nokia3110
Sir,i required nokia 3110c good pm file.plese help me.
Old 02-19-2011, 13:04   #14 (permalink)
Member: 1519991
Question Nokia3110
I have anokia3110c ''contact service'' problem.plese help me
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
unlock Service Provider Code for PrimeCo (USA) in 6185 Nokia Phone X-plot Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 05-11-2000 03:43
gsm service provider sidou Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-30-2000 11:09
FREE SP unlock service timxy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-22-1999 16:05
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.24198 seconds with 9 queries
