Old 08-12-2007, 10:26   #1 (permalink)
Member: 215212
Thanks Meter: 4
problem with 1110i
I have problem with 1110 i phone :
1st Boot Ok, DCT4, UPP: 2201
Fl0: 0x01000000-0x01FFFFFF,00A82228,
Algorithm: u_intel.fia, Ver: 4.57.0
Algorithm Ok, MSID: 844E60EBF4FCCB25192142DB5B
Decoded MSID: 3E4EBAE9-004E3272-A8000000
Encoded FAID: 767FD4DB-5E119356-8CFB366B
Erasing: 0x01000000-0x0100FFFF ...
Erasing Error: 10, at: 0x01000000-0x0100FFFF, 940207, Time: 00:00
Process Failed, Repowering Mobile
can anybody help me please
Old 08-12-2007, 10:54   #2 (permalink)
mobilelink's Avatar
Member: 318277
Thanks Meter: 92
Hi mate! 1st take a back up of PM and try to flash it in a slower mode (cahnge d flashing speed)
Cheers!
Old 08-12-2007, 11:45   #3 (permalink)
Member: 438406
Thanks Meter: 3
dear try to flash it with jaf
br chiepsy man
Old 08-12-2007, 12:42   #4 (permalink)
News4GSM's Avatar
Member: 561120
Thanks Meter: 5
or maybe
1. try to search for other "u_intel.fia" files ( files that contain flashloader ) ... maybe this file is too old. ( replace the JAF or UFS file with the new one, maybe install some new flashloaders )
2. maybe the flash is damaged somehow ( poor soldering because some mecanical failure ) - if first step is not working at all try to resolder the flash
( i don't remember if the flash is solderable or not for this model )
First you can try to put some plastic or paper on the flash and close the phone, if the hardware failiure is small then you will be able to use the phone a while )
Old 08-12-2007, 12:47   #5 (permalink)
Mourad120's Avatar
Member: 155016
Thanks Meter: 130
this fia file is not old
that might be the cause ...unfortunately the Flash memory is glued
Old 08-12-2007, 12:52   #6 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
yes brthr i agree wit u.... this fault (process failed reproving mobile) is the problem of mainly flash ic ....u can solve ur problem by reballing this ic .....
Old 08-12-2007, 16:17   #7 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
in this log we can see there is no flash id so reball or replace flash ic
post result
Old 08-12-2007, 17:59   #8 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
Thanks Meter: 301
flash wiz jaf 100% ok
u can even flash wiz 1600 latest flash file & change lcd...(1600 lcd)
wiz jaf only
enjoy!!
Old 08-12-2007, 21:34   #9 (permalink)
kashi4gul's Avatar
Member: 460762
Sonork: 100.1592082
Thanks Meter: 3,104
Either Flash Chip is damaged
or may b possible ur computer
is infected by Virus.
B.Regards,.
kashi4gul
Problem with nokia 1110i key 2,5,8,0 nellabe Nokia Hardware & Hardware Repair 5 01-01-2010 22:05
boot problem with 1110i zemiklo MT-BOX 4 07-29-2007 03:35
problem with contrast 1110i after unlock shayan744 Universalbox 2 02-26-2007 06:18
"FAILED, check cable " problem with 1110i bozzan MT-BOX 9 12-10-2006 19:39
Page generated in 0.25630 seconds with 9 queries
