11-21-2004, 06:56 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | 7610 flash ic and uem solder type r they (nokia) using new tricks of protection using some kind of new solder alloy type which required different kind of hot degree for melting instead of resin coz it's very hard to melt the solder using normal temperature, a lot of it ended up with lost point at the flash and uem ic can we replace the bottom one sec 418 with 413 like in 3200 ? regards |
11-22-2004, 19:58 | #7 (permalink) |
Freak Poster Join Date: Aug 2004 Location: The great pakistan
Member: 79823 Status: Offline Thanks Meter: 26 | but mind you with a good soldring paste like from germany i dond remember the name right now and use the smallest nosele or second to smallest \daanish |
6310 Flash IC and 6510 Flash IC... | LoveLess | Nokia Hardware & Hardware Repair | 5 | 04-14-2007 12:09 |
7610 flash ic (f10) not detected | psyrooze | WD2 & APE (Symbian Phones) | 1 | 08-25-2006 19:21 |
7610 flash ic | GSMJordan | Nokia Hardware & Hardware Repair | 6 | 10-05-2005 22:29 |
7610 Flash Ic Compatable..., | Byte | Nokia Hardware & Hardware Repair | 2 | 09-04-2005 12:12 |
