05-19-2008, 05:45 | #2 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | very old problem man, and very easy solution! as always, check vcharge line to tahvo!, if ok, check vbat and bsi line, if all ok, then change tahvo, BUT do not forget to write working pm first and do not forget to back simlock data! Byte |
The Following User Says Thank You to Byte For This Useful Post: |
06-16-2008, 05:59 | #3 (permalink) |
No Life Poster Join Date: Feb 2007 Age: 41
Member: 449518 Status: Offline Thanks Meter: 585 | as always, check vcharge line to tahvo!, if ok, check vbat and bsi line, if all ok, then change tahvo, BUT do not forget to write working pm first and do not forget to back simlock data! ........me 4 tested............... |
nokia 6680 charging problem | bharat_3013 | Nokia Base Band 5 ( BB-5 ) | 7 | 02-02-2013 13:52 |
nokia 6680 charging ok but no power on | tuban_gsm | Nokia Hardware & Hardware Repair | 3 | 02-02-2010 06:18 |
6680 charging problem | Bismillah_mob | Nokia Hardware & Hardware Repair | 14 | 09-14-2009 22:50 |
6680 charging Problem | jayanandana | Nokia Base Band 5 ( BB-5 ) | 2 | 11-28-2008 16:20 |
6680 charging problem !!! | waleed2500 | Nokia Hardware & Hardware Repair | 4 | 06-25-2008 16:30 |
