05-05-2011, 15:50 | #1 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | nokia 6700s hardware solution here . Nokia 6700s slide No network Signal solution [IMG]http://2.bp.********.com/_haRAPmO1Seg/TPuLua-MrrI/AAAAAAAAAyM/Egw-8OMZbLM/s320/nokia+6700s+No+network+signal+solution.jpg[/IMG] |
The Following 3 Users Say Thank You to aZimBahar For This Useful Post: |
05-05-2011, 15:51 | #2 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700 slide bluetooth operation failed solution [IMG]http://2.bp.********.com/_haRAPmO1Seg/TPuEEPgAvfI/AAAAAAAAAyI/kzC97KIHaIo/s320/nokia+6700s+bluetooth%252C+FM++solution.jpg[/IMG] |
05-05-2011, 15:51 | #3 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700 slide keypad backlight LED solution [IMG]http://1.bp.********.com/_haRAPmO1Seg/TPpFlPrNlWI/AAAAAAAAAyA/6v_7i2x-950/s320/nokia+6700s+keypad+backlight+led+solution.jpg[/IMG] |
05-05-2011, 15:52 | #4 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700s slide Charger Not Supported Problem Solution [IMG]http://2.bp.********.com/_haRAPmO1Seg/TPdK4y7WuyI/AAAAAAAAAx4/4TOGSeqCgCU/s320/nokia+6700s+chargenot+supported+solution.jpg[/IMG] |
05-05-2011, 15:52 | #5 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700 slide Display Backlight LED Problem Solution [IMG]http://1.bp.********.com/_haRAPmO1Seg/TPoyB1M3P3I/AAAAAAAAAx8/VoxWuS0-w9w/s320/Nokia+6700s+lcd+display+backlight+solution.jpg[/IMG] |
05-05-2011, 15:52 | #6 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700s Local mode/Test mode Solution [IMG]http://2.bp.********.com/_haRAPmO1Seg/TPdIcqOuY4I/AAAAAAAAAx0/6373Kv-rjYE/s1600/nokia+6700s+local+mode+solution.jpg[/IMG] |
05-05-2011, 15:53 | #7 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700 slide camera switch connection tracks [IMG]http://4.bp.********.com/_haRAPmO1Seg/TPc_j5SYN6I/AAAAAAAAAxw/w1gWbUQQ1XM/s320/nokia+6700s+camera+switch+jumper+solution.jpg[/IMG] |
05-05-2011, 15:53 | #8 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700 Slide End/Power ON OFF Key Connection Line Paths [IMG]http://3.bp.********.com/_haRAPmO1Seg/TPc7oY5S95I/AAAAAAAAAxs/FSavoaVzBMs/s320/Nokia+6700+slide+end+power+on+off+key+jumper+ways. jpg[/IMG] |
The Following User Says Thank You to aZimBahar For This Useful Post: |
05-05-2011, 15:54 | #9 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700 microSD memory card not detected solution [IMG]http://3.bp.********.com/_haRAPmO1Seg/TPX7kMRMikI/AAAAAAAAAxo/oWg91j6PsNw/s1600/nokia+6700s+mmc+solution.jpg[/IMG] |
05-05-2011, 15:54 | #10 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700s flex ribbon cable [IMG]http://1.bp.********.com/_haRAPmO1Seg/TPTx0uqeDaI/AAAAAAAAAxc/6LS1q0jjMuc/s320/flex+cable.jpg[/IMG] Nokia 6700s Earpiece Speaker Solution [IMG]http://2.bp.********.com/_haRAPmO1Seg/TPT5TPxugjI/AAAAAAAAAxg/t3U7pURirBk/s320/nokia+6700+slide+earpiece+speaker+solution.jpg[/IMG] |
05-05-2011, 15:55 | #11 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700 sim card connection tracks [IMG]http://2.bp.********.com/_haRAPmO1Seg/TPX2vDcnNlI/AAAAAAAAAxk/ZrOgSEj6HJo/s320/nokia+6700s+insert+sim+card+solution.jpg[/IMG] |
05-05-2011, 15:55 | #12 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700 slide flex cable or ribbon wire [IMG]http://1.bp.********.com/_haRAPmO1Seg/TPTx0uqeDaI/AAAAAAAAAxc/6LS1q0jjMuc/s320/flex+cable.jpg[/IMG] Nokia 6700s mic, *****piece problem solution [IMG]http://4.bp.********.com/_haRAPmO1Seg/TPTxpPg7ayI/AAAAAAAAAxY/cIFgN0abcvU/s320/nokia+6700s+mic+solution.jpg[/IMG] |
05-05-2011, 15:55 | #13 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Solution for Nokia 6700s slide Not working ringer or hands free speaker [IMG]http://3.bp.********.com/_haRAPmO1Seg/TPO5DgjlwzI/AAAAAAAAAxQ/QS95kFmfXdA/s320/nokia+6700+slide+ringer+speaker+solution.jpg[/IMG] |
05-05-2011, 15:56 | #14 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700 slide Display Problem Solution [IMG]http://3.bp.********.com/_haRAPmO1Seg/TNeXj7VuP_I/AAAAAAAAAsU/F2HiBRWecqA/s320/6700+slide+display+IC+jumper+ways.jpg[/IMG] |
05-05-2011, 15:56 | #15 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Nokia 6700 Slide Upper Keypad Connection Aside from keypad button connection, there also other major operational circuit is being connected to it like the LCD display, microphone, earpiece and camera.[IMG]http://2.bp.********.com/_haRAPmO1Seg/TNa0FykRuoI/AAAAAAAAAsM/djbrymsl8w0/s320/nokia+6700+slide+navigation+keypad+solution.jpg[/IMG] Once the flexible cable wire damaged or breakdown all of these connected circuit will show some difficulty and problem. Nokia 6700 slide Flexible Cable Wire [IMG]http://3.bp.********.com/_haRAPmO1Seg/TNaxkpcfU6I/AAAAAAAAAsI/tdbyapwz8N8/s320/nokia+6700+slide+flex+cable+matrix.jpg[/IMG] |
