Nokia 7 Plus TA-1046 Bypass Google Account If you've tried multiple methods to bypass frp Nokia 7 Plus TA-1046, and unable to bypass frp lock, because off course new security patch level now biting difficult to bypass google account, after doing so many steps then I am successfully bypassed google account Nokia 7 Plus TA-1046 so that's why I've decided to share with you guys new method to bypass frp on Nokia 7 Plus TA-1046 This method has been tested with [Nokia 7 Plus TA-1046 Android 8.1]. Bypass Google account Nokia 7 Plus TA-1046. -Power on your device. -Connect your device to Wifi. -Now, set up your device then go to " Verify Google Account" Screen. -Then back to "Welcome Screen". -Now you have to enable "talkback features" on your Device. -from the "welcome screen" on your device screen then Tap on "Vision Settings" icon. -Then tap on "talkback" then turn on talkback features. -after that, you have talkback tutorial on your device screen. -Now draw "L" on your Nokia 7 Plus screen to bring "Global Context Menu". -When "Global Context Menu" Pops up* show on your device screen - then double tap on "Talkback Settings" -Now again draw "L". -Then double tap on "pause talkback" then double back on "Ok". -From "talkback settings" screen then scroll down, then tap on "Help & Feedback". -Select the "Get Started with Voice" option. -Now you will able to see a "YouTube Video" on your Screen. then play the "Youtube Video" after that tap on "Clock" icon. -Note: IF you unable to select the "Clock" icon then you can tap on "Youtube" title. -Now you will access "Chrome Browser" on your device. -Then select "No thanks" and then "Accept & Continue". -Then click on the search bar and type "download frp tools gadgetsdr" -Then goto very first search result. That is according to our Site "Gadgetsdr.com". --Download from there "Apex Launcher.apk" -While downloading finish, you will get a popup then tap on "Open " from that popup. -Now you will get a "Security popup window" on your device screen. -Then tap on settings then enable "Unknown Source" from there. -Then tap on "back key" then install then Apex launcher by >next > next > Open. -Then you will access home screen. -Then again tap on "Chrome Brower". -Now download from there "FRP Bypass(GD).apk" -Also, download from there "Google Account Manager 6.0.apk" -Once downloading finish "Google Account Manager 6.0.apk" then*we will get again a popup button. then click on "Open" button from that popup window. -Install the "Google Account Manager" By-install =>Install => Next => Done. -Then back to "apex launcher" home screen by tapping "back key". -Then Goto "downloads". -Install the "FRP bypass(GD).apk" (that you downloaded before. -After installation done tap on "Open" and open the "FRP Bypass GD" applications. -After open the applications - you will see the "retype password" screen. -Then tap on "3" dots from the top right corner of your device. -Then tap on "Browser Sign IN" from that popup. -Then sign in there with your any Valid Gmail ID. -Then "Reboot". -Join our details information about Bypass FRP Nokia 7 Plus TA-1046 section here. check your missing steps.. DOWNLOAD: BYPASS GOOGLE ACCOUNT NOKIA 7 PLUS DOWNLOAD FRP BYPASS TOOLS NOTE:-I CANNOT FIND NOKIA NEW ANDROID SECTION .. SO THATS WHY I POST IT TO HERE ... SORRY.. |
Any method to remove FRP for latest update?This method doesen't work anymore. |
Try this method once:=https://www.bypassfrpfiles.com/2018/12/bypass-frp-nokia-7-1/ |
