04-02-2012, 03:14 | #1 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1343862 Status: Offline Sonork: 1614324 Thanks Meter: 18 | masters of nokia hardware help Hello, anyone knows how to hardware change imei of nokia bb5 ? for example n97 wich IC holds imei info ? thanks |
The Following User Says Thank You to chaceco For This Useful Post: |
04-02-2012, 03:35 | #2 (permalink) |
No Life Poster Join Date: May 2008
Member: 772651 Status: Offline Thanks Meter: 1,694 | ist of all you can not change imei in nokia phone ... you can change rap from another set which holds imei , but before changing you need to have rpl backup which when changed backup should also be changed. |
The Following User Says Thank You to ajit bs For This Useful Post: |
04-02-2012, 03:52 | #3 (permalink) |
Member: 1343862 Status: Offline Sonork: 1614324 Thanks Meter: 18 | ok so you said that changing cpu imei will change? phone 1 : imei 0000 this phone needs new imei phone 2: imei 1111 1) backup rpl from original phone imei 0000 2) desolder cpu from phone 2 3) desolder cpu from phone 1 4) solder cpu from phone 2 to mainboard of phone 1 5) write back origina rpl on phone 1? thats correct? |
04-02-2012, 05:10 | #6 (permalink) |
Insane Poster Join Date: Aug 2010
Member: 1360145 Status: Offline Thanks Meter: 12 | Generally cpu holds RPL. Get a cpu and flash ic holding good imei(same phone). Replace those ic with imei corropted ic.(similar phone). your problem solved .No need to back rpl(imei). NOTE=if you want to change only cpu you need to keep backup of RPL,PM and important data. That is what i know ...May it help you... |
The Following User Says Thank You to inambo_007 For This Useful Post: |
04-02-2012, 07:09 | #7 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | if u want to change imei of n97 .u need another n97 set.replace both combo and flash ic. no need any software for change imei. cpu and flash ic holds imei in bb5 set,if both ic ok, and u r expert to change it ,imei will b changed. |
The Following User Says Thank You to mahzra azra For This Useful Post: |
04-23-2012, 19:12 | #9 (permalink) |
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | yes. in many bb5 sets like 3110 6300 5300 5130 2690 and many more. i use simple tool as stencils<jali>,one surgical blade,ppd,hot gun not infrared,and a iron. but my friend i have rebolling ic for eight years and now yet whole day i only reboll ic. it means practice is most impotent to reboll ic. one thing in dct4 set only uem<power ic>hold imei. |
08-03-2013, 19:43 | #10 (permalink) | |
Junior Member Join Date: Feb 2009
Member: 978659 Status: Offline Thanks Meter: 0 | Quote:
reball ic and replace it, it only works for 2 hrs or sometimes for 2days but never forever why plz answer this, its really must for me | |
08-03-2013, 19:50 | #11 (permalink) | |
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Quote:
Plz write clearly and in details. | |
08-03-2013, 19:40 | #12 (permalink) |
Member: 978659 Status: Offline Thanks Meter: 0 | bro, can u plz tell me that whenever i change and reball ic and replace it, it only works for 2 hrs or sometimes for 2days but never forever why plz answer this, its really must for me |
08-03-2013, 20:18 | #13 (permalink) |
Member: 978659 Status: Offline Thanks Meter: 0 | i mean to say, that whenever i change an ic it works for few hours and after that it stops working but after reheating it again works and again after few hours it stops and so on. For example betty of 2700c or tahvo of 3110c or any mtk. |
