02-26-2006, 10:47 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 40
Member: 110527 Status: Offline Thanks Meter: 0 | Nokia 7250 dead ringer Got a Nokia 7250 that's been dropped & as a result doesn't ring. Opened the phone & can't see anything wrong or cracked or the location of the ringer. Everything works, keypad tones, vibrates. Just doesn't ring. Any help, ideas most appreciated. Thnx, Adam |
03-02-2006, 11:15 | #3 (permalink) |
Junior Member Join Date: Aug 2005 Age: 46
Member: 166650 Status: Offline Thanks Meter: 14 | Sorry I Have no pictures at the moment, but i have had this fault many times. look on the front of the pc board about a centimeter across to the right of the flash ic you will see a small black bga ic "chip", i normally reheat this or change it and the phone works 100%. try this and good luck. billycool77 |
The Following User Says Thank You to billycool77 For This Useful Post: |
03-05-2006, 13:39 | #4 (permalink) |
Member: 110527 Status: Offline Thanks Meter: 0 | Fixed! hello, thanx 4 all the replies. I couldn't find the items mentioned but did discover corrosive build up on a few components which i removed. Could have been causing short circuits. At least it works now. Thnx again Adam |
Nokia 7250 dead after try to flash!! | Ciux | MT-BOX | 8 | 06-12-2006 20:56 |
NOKIA 7250 DEAD AFTER PUT 12V ON SMALL BATERY INSIDE PHONE..urgent help | crossings | Nokia Hardware & Hardware Repair | 5 | 12-09-2004 18:03 |
Nokia 7650 Dead When Changing Ringer | GSM MIND | WD2 & APE (Symbian Phones) | 4 | 10-17-2004 04:57 |
7250 Dead | WINPINPH1 | Nokia Hardware & Hardware Repair | 2 | 11-15-2003 02:23 |
7250 Dead | WINPINPH1 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 11-14-2003 04:46 |
