01-25-2006, 22:41 | #1 (permalink) |
Insane Poster Join Date: Jul 2005 Location: London, UK Age: 38
Member: 164504 Status: Offline Thanks Meter: 17 | Nokia 7610+6230 software problem I have come to the conclusion that a full flash may be in order for both phones, but the problem is that I have no idea how to flash phones. I have download this file ( rh-51_dp_ea_v_6_0_mcu6_0522_0 )from: http://www.gsmpartner.pl It is an .exe and I installed it on my computer. But I don't know where to go from there. Is there a step-by-step guide to flash this phone (nokia 7610) any advice would be greatly appreciated. Last edited by ronzinio; 01-26-2006 at 08:24. |
01-26-2006, 18:12 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | hi, it is easy really. open the dctxbb5 short cut you should see on your desktop and click on "connect" (when box is connect to computer). next select dct4 from the tab to the right of the screen. this is to select the group that contains your phone (dct3=old, dct4=newish, wd2=newisher, bb5=newest). now connect your phone into its connector and plug it all into the ufs box. if the phone powers on, then you can click "info" at the top of the ufs window (right from where you saw "connect"), the phone type box will now be auto filled along with a display of model info. if the phone is a dead set (no power) then you will have to select its type manually. in the phone type box, select your phone model from list (it is in alphabetical order of model type not number). click the box next to "mcu", if you have installed a data package for this phone type you will be sent to the folder contaning flash files automatically, if not, you must install the correct data package. select the biggest file displayed in the window (ends with the number 0). this is your MCU (Master or Micro Control Unit), the main software of your phone. do the same for PPM (post programmable memory), which is the language packs of your phone. finally select the CNT (content pack) which is the pictures and tones preinstalled. for a uk user as example select: MCU: 3.640 ppm: 3.64a cnt: 3.64.ucp_a see the a and ucp_a which identifies the pack. use a for each if you are a new user. now just click where it says "flash" and you will be away. hope this will get you started mate, i love twister/ufs tool |
01-27-2006, 23:01 | #3 (permalink) |
Member: 164504 Status: Offline Thanks Meter: 17 | OK so I flashed the 7610 with the flash tiles, been testing it today. But when I touch the buttons on the left hand side, for some reason the phone likes to restart itself. The software version on my phone is: v6.0522.0. Could it be that my keypad membrane might need replacing? Or possibly a bad flash even though the phone seems ok |
I need FM Radio software for NOKIA 7610......plz............ | reach2emu | Nokia Multimedia | 6 | 01-06-2008 10:39 |
Nokia 7610 Software Problem | lahoot | Nokia Hardware & Hardware Repair | 5 | 07-30-2006 18:23 |
nokia 7610 software - i nd help!!! | edge_2723 | Nokia Multimedia | 0 | 05-24-2006 16:19 |
Nokia 7610 Softwares | Cksam | Nokia Multimedia | 3 | 04-08-2006 14:08 |
newest nokia 6230 software??? | robbie9911 | UFS2 + UFS3-Tornadoflasher | 4 | 06-11-2005 14:18 |
