Old 08-18-2007, 00:49   #1 (permalink)
Member: 83618
Thanks Meter: 2
Nokia 7610 network
Hello evrey body ...
I have Nokia 7610
and its signal drop down suddenly ..
and when I searched for the networks , it gave after 4 min almost ( no network found )
and as it dropped down .. it took the network signal suddenly too
I'm a beginner so I need your help to solve it ....
thanx a lot for you allllllllllllllllll
Old 08-18-2007, 03:56   #2 (permalink)
Member: 285779
Thanks Meter: 49
hi sir ,
replace P.A -> RF ic -> UEM
Old 08-18-2007, 04:04   #3 (permalink)
colonelrte's Avatar
Member: 562532
Thanks Meter: 10
mate b4 doing hardware repair.. try 2 repair software 1st..ful erase dn full flash.. after flashing write good PM..use ufs+hwk..flash with latest version.. gud luck..
Old 08-18-2007, 04:12   #4 (permalink)
tabuki's Avatar
Member: 455665
Thanks Meter: 36
do what they say! added: re-solder rf ic and UEM first before change
Old 08-18-2007, 05:02   #5 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
dear brother, your problem may be solved by software, with lates version files.
try it and post the results.
I have Nokia 7610
Old 08-21-2007, 20:18   #6 (permalink)
Member: 83618
Thanks Meter: 2
thanx every body ...
I really tired to format user era .... by pressing * 3 (call button)
and I did it well ... but still have the same prob
maybe I have to reflash it .. with latest V ... becoz my V is 4.0421.4
HW is the last thing I'm thinking of guys ...
but after SW and get no result , i will do hard ware repair ...
thanx for every body ...
I'm really thanxful .....
I would do it ...
and post the result very soon ....
Old 08-21-2007, 20:25   #7 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
I have Nokia 7610
Write pm file first and unlock the phone.
or
Replace the PA IC and observe the signal if still desame problem..
Replace also the RF IC...
br
capri
Old 04-16-2008, 01:51   #8 (permalink)
..::My3gtech::..'s Avatar
Member: 158032
Thanks Meter: 331
nice man i have also this problem that i can solve with direct jumper from antina pad to antina just try and post the result because some time we ignore little things so try it...
Omairbutt786
The Following User Says Thank You to ..::My3gtech::.. For This Useful Post:
Old 05-17-2008, 07:38   #9 (permalink)
Member: 763327
Thanks Meter: 2
nokia 7610 networkproblem
The Following User Says Thank You to Govi_mobile For This Useful Post:
Old 06-16-2008, 05:34   #10 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
dear brother, your problem may be solved by software, with lates version files. flash with jaf........
Old 08-23-2010, 17:07   #11 (permalink)
Member: 587299
Thanks Meter: 2
yes same problem here but nice explain
The Following User Says Thank You to faisaljana For This Useful Post:
Old 03-16-2011, 03:02   #12 (permalink)
Member: 1267116
Thanks Meter: 2
me too..same problem here!i'm a beginner..i have also done it but nothings change. same always!omairbutt786 is rigth.i do also ignore small things like that..software + basic first b4 hardware!(^_^)
thanks!
The Following User Says Thank You to Aris Joseph For This Useful Post:
Old 04-01-2011, 04:16   #13 (permalink)
Member: 1547008
hi, sir try to jumper antena pad,
Nokia 3120 Network Problem ramdev_mobbile Nokia Hardware & Hardware Repair 3 07-13-2010 08:46
nokia 7610 network few seconds gon help me pls palav Nokia Hardware & Hardware Repair 1 02-10-2010 11:19
nokia 7610 network pronim Nokia Hardware & Hardware Repair 1 10-27-2009 14:33
nokia 7610 network problem saqi160 Nokia Hardware & Hardware Repair 5 06-05-2009 15:28
nokia 7610 network problom KAMARU Nokia Hardware & Hardware Repair 3 04-15-2007 07:52
Page generated in 0.22797 seconds with 9 queries
