nokia 7610 startup failed contact the retailer nokia 7610 startup failed contact the retailer,flash,erase flash but ui settinng not done yi setting failed,format user area done any soloution |
i think that is flash ic problem bro ,change it , 32 mb first good luck |
Hello first check software (that you do it) hardware rehot big flash chip(ape chip) or reball this chip rehot(reball) SD ram chip. post result |
ram damage only 10% bro sorry hope you understand |
Hi chek config key rpl |
Just Hand Format * + 3 + Call + Put On.... |
[format = power+press & hold call+*+3] SOME TIME THIS method working for this problem.u can try this way. |
just hand format brother....*+3+call+power. i tested many times...good luck |
i have nokia 7610Nokia 7610 phone startup failed contact the Retailer i have nokia 7610 i am 3 time hand formate * 3 send button but phone did same condition |
try use ufs.format user area with 2x same time example complete 00.45 complete 00.47 complete 00.47 until get twice same time... |
