Old 09-18-2008, 13:24   #1 (permalink)
Member: 401625
Nokia 8800 no backlight & keypad light.
As the title says I have a nokia 8800 with no backlight and no keypad light. What can be the problem? main flex or someting else?
Someone got the solution?
thanks.
Old 09-19-2008, 10:31   #2 (permalink)
Member: 401625
Kick. Someone said i had to change the 2 chips, is there a other solution beside that?
Old 09-19-2008, 10:47   #3 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
cheak the light ic suplt and chang the light ic
Old 09-19-2008, 10:48   #4 (permalink)
Member: 662678
Thanks Meter: 2,539
cheak the v+ supply of light ic
Old 05-18-2009, 14:07   #5 (permalink)
Member: 41057
Thanks Meter: 5
I have the same roblem. Light IC is changed, V+ from battery is O.K. Keypad light comes on,but LCD backlight still black
LCD and Flex is O.K with another board.
Old 06-01-2009, 12:23   #6 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
I've the same problem! No backlight on LCD but the keyboard is ok.
Any help?
Old 06-16-2009, 19:37   #7 (permalink)
Member: 153584
Thanks Meter: 4
my nokia 8800 sirocco only lights up when its turnt on then when it enters standby the light never comes back on unless u turn it off and on again also the camera freezes the phone when you try an enter it
Old 07-16-2009, 08:09   #8 (permalink)
luqmaan's Avatar
Member: 617428
Thanks Meter: 52
tried flex and lcd still same problem,when i put into another mainboard it works so it must be hardware anyone have solution.
Old 07-25-2009, 14:11   #9 (permalink)
Member: 153584
Thanks Meter: 4
anyone ???????????
Old 08-06-2009, 09:51   #10 (permalink)
Member: 478116
Thanks Meter: 11
Change N300 work 100%
N300-->N1300 6103
Old 08-30-2010, 11:29   #11 (permalink)
Member: 41057
Thanks Meter: 5
..............my solution
Old 02-19-2018, 14:38   #12 (permalink)
Member: 2807999
I have the same problem can someone please tell me why my keypad lights and backlight not working and a pic of the motherboard what to change or do to fix please
nokia 1202 no display & keypad light problem palav Nokia Hardware & Hardware Repair 17 08-14-2014 11:22
HELP nokia 5320d no lcd and keypad light navin71 Nokia Hardware & Hardware Repair 13 08-26-2012 10:12
k530i no lcd & keypad light.... sumeet922 Sony Ericsson Hardware Repair 0 01-16-2010 20:35
w810 no dispaly & keypad light gul-fraz Sony Ericsson Hardware Repair 1 05-15-2008 18:20
w600i no backlight nor keypad light lamont_dun Sony Ericsson Hardware Repair 0 11-22-2006 03:12
Page generated in 0.22717 seconds with 10 queries
