10-14-2003, 16:57 | #3 (permalink) |
Junior Member Join Date: Oct 2003 Age: 34
Member: 41284 Status: Offline Thanks Meter: 0 | hi! i had tha same problem after running from police with a can of beam&coke in the same pocket as my phone.. (so of course, its their fault..) this is at your own risk!!! i used a sharp knife to cut out the buttons, leaving a small section still joined, so that i could flip over the button and clean the terminal on the board and under the button. In fact, i just had to soak up some of the stickyness and then everything was back to normal... hope that helps as a cheap alternative. regards ryan |
10-15-2003, 14:44 | #4 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Port Harcourt, River State, Nigeria Age: 45
Member: 25150 Status: Offline Thanks Meter: 8 | broken line is your problem notice there is a broken line some where between 1 and 2 or * and 0, which supplies to the 1,4,7,* u have problem with, they are in a straight line so get there supply of current from a single surce, reconnect this broken line and u are ok. sory if this is coming in late. gibso. |
1110-keypade/1.4.7.*.menu.call.not woking | rahmanp | Nokia Hardware & Hardware Repair | 3 | 07-24-2007 19:48 |
T630 keypad problem:key 1,4,7,* not work | duha2 | Sony Ericsson Hardware Repair | 4 | 02-15-2007 14:57 |
6600 1,4,7 Keypad Not Working | RAHUL_CELLCARE | WD2 & APE (Symbian Phones) | 5 | 07-01-2006 12:51 |
8310 keyboard 1,4,7, and # not working | Peter_Muir | Nokia Hardware & Hardware Repair | 17 | 04-12-2005 22:45 |
a300 key's 1,4,7 not working,keypad ok | Destructor | Samsung Hardware Repair | 2 | 05-06-2004 23:58 |
