2.check fm antina. 3.replace fm radio ic. try this solution one by one. |
sir i want to c1-00 keypad solution |
sir i want to nokia cable finder latest version |
n70 white screen any solution pls help |
2680 slide, came with white display i changed fluxwire, nd display....still it shows white.. any solution?? is tht display ic problem? |
2.replace flex connector. try this solution one by one. |
handsfree not working when handsfree is connected. |
nokia n97 switch conector is broken i cant power on how to power with charger? please |
nokia 6500 shorted problem! my nokia 6500 is shorted problem its working but its easily to battery low! do you have a solution of this! thanks! hope to respond |
hello everybody, I've next problem: nokia 5230 and 5800 have the same problem, they don't power on, when I press power on button,no vibration and display lights dimly and does nothing, HWK can't check/read info... what happens? has anybody solved same problem? please help me |
i have nokia 5310 no network water damage plss help me |
please i have nokia 5530 anytime i call immediately they pick the phone we off himself, OR if they call me when i pick it will off please what is the solution i try to flash the phone did not connect direct with hwk, and i used mxkey with usb it does not connect please help |
nokia 3110 keypaid problem dizit auto play solave problem |
I need all solution for model 2630... can u all help me..? |
