02-13-2012, 11:29 | #1 (permalink) |
Product Manager Join Date: Mar 2011 Location: kuwait Age: 32
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Nokia Asha 200 support Br Dipankor-ctg Nokia Asha 200 support Br Dipankor-ctg |
The Following 4 Users Say Thank You to Dipankor-ctg For This Useful Post: |
02-13-2012, 11:31 | #2 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Keys and parts
Br Dipankor-ctg |
02-13-2012, 11:33 | #4 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Insert a SIM card and battery This phone is intended for use with a BL-5J battery. Always use original Nokia batteries. If you only have one SIM card, insert the card into the internal SIM card holder.
Br Dipankor-ctg |
The Following User Says Thank You to Dipankor-ctg For This Useful Post: |
02-13-2012, 11:35 | #5 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Insert a second SIM card
Br Dipankor-ctg |
02-13-2012, 11:36 | #6 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Charge the battery Your battery has been partially charged at the factory, but you may need to recharge it before you can switch on your phone for the first time. If the phone indicates a low charge, do the following:
If the battery is completely discharged, it may take several minutes before the charging indicator is displayed or before any calls can be made. If the battery has not been used for a long time, to begin charging, you may need to connect the charger, then disconnect and reconnect it. Br Dipankor-ctg |
02-13-2012, 11:38 | #7 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Switch the phone on or off Press and hold the power key until the phone vibrates. Br Dipankor-ctg |
The Following 2 Users Say Thank You to Dipankor-ctg For This Useful Post: |
02-13-2012, 11:40 | #8 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Insert a memory card Use only compatible memory cards approved by Nokia for use with this device. Incompatible cards may damage the card and the device and corrupt data stored on the card. Your phone supports memory cards with a capacity of up to 32 GB.
You can remove or replace the memory card without switching the phone off. Remove the memory cardPush the card in, until it is released, and pull the card out. Br Dipankor-ctg |
02-13-2012, 11:40 | #9 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | GSM antenna Avoid touching the antenna area while the antenna is in use. Contact with antennas affects the communication quality and may reduce battery life due to higher power level during operation. Br Dipankor-ctg |
02-13-2012, 11:41 | #10 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Connect a headset Br Dipankor-ctg |
02-13-2012, 11:42 | #11 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Attach the wrist strap Remove the back cover, thread the strap through the hole, and loop the strap around the wrist strap peg. Br Dipankor-ctg |
02-13-2012, 11:45 | #12 (permalink) |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Hardware-Repair Area Wait And See Full Hardware Repair & Solution Come in HARDWARE Team Bangladesh Br Dipankor-ctg |
The Following 3 Users Say Thank You to Dipankor-ctg For This Useful Post: |
02-14-2012, 08:37 | #13 (permalink) |
Insane Poster Join Date: Nov 2007 Location: United Arab Emirates
Member: 623831 Status: Offline Sonork: 100.1609055 Thanks Meter: 5 | plz help me Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast... RXD=6 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100026A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Manufacturer: ST & NUMONYX, Device: Unknow CPU: SC6600L2 Flash: NOR_UNKNOWN |
02-14-2012, 18:26 | #14 (permalink) | |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Quote:
you post wring write Section post now | |
