04-06-2011, 07:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Nokia C2-01 Ear speaker not working Problem Solution This repair solution covers for Nokia C2-01 does not earpiece speaker problem. This problem occurs or happens if the unit suffered water damage or wet, heavy cases or accidentally during use. An oxidation to build up the ear can also cause failure. This solution provides the basic steps on how to fix and repair the phone. Only refer to the solution offered below and follow a few simple steps we are prepared. Tips on repairing Nokia C2-01 does not ear speaker problem: 1. Check the receiver connectors, if not bent or damaged then test using a multimeter, if found damaged replace. 2. Clean the ear speaker jack contacts on the PCB. 3. Check / replace the filter capacitors and coils. 4. Trace the path of the speaker connector to filter once the PCB terminal pads. |
