Nokia Buzzer C2-01, No Ringtones Sound Problem Solution Nokia Buzzer C2-01, No Ringtones Sound Problem Solution Another Nokia-c2-01-GsmAngel solution by covering the Buzzer speaker problem, or not ringtones and alert sounds can be heard on the device even the volume knob was already set at high level. http://www.u2ugsm.com/blog/wp-conten...ut-300x144.jpg This solution offers among which components need to check to determine and return the phone buzzer function working again. Just refer to it and follow some step by step procedures which we prepared. Steps to define procedures C2-01 Nokia buzzer speaker problem: 1. Visual inspection of the IHF speaker buzzer for possible alignment of the terminals and / or using a multimeter, replace if found damaged. Clean if it oxidized. 2. Clean the speaker connector PCB contact surfaces. 3. Check / replace the filter capacitors and coils. 4. Trace both positive and negative connecting paths. 5. If the above procedures, won, t solve the problem. PEARL The IC will be the last option to work with his. Perhaps only reformulates the problem. __________________ daily visit our forum to gain full gsm support |
