10-23-2013, 07:11 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Srilanka
Member: 943193 Status: Offline Thanks Meter: 3 | Nokia C2-03 Display light not working,,, Nokia C2-03 Display light not working,, but main board light are working ,pls help it is little water damage, i changed new display, new flex cable also but same problem, give any one idea to do my work? any expert??? |
10-23-2013, 18:31 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | check this 2 attach pictures , hope it help u . |
The Following 3 Users Say Thank You to .:SARCAR:. For This Useful Post: |
10-25-2013, 17:04 | #5 (permalink) |
Member: 943193 Status: Offline Thanks Meter: 3 | sir i have check all connections are fine ,still same problem pls help? and i changed diode and coil, but same problem,, and i shaked UEM also, problem same same...... Last edited by aroos84; 10-25-2013 at 17:13. |
10-25-2013, 20:31 | #6 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | @sudhakarkg , no it's not possible . X3-02 touch ic need to be change with new one . @aroos84 , try to replace lcd connector & check . as it's water damage so there is greater chance to xgold cpu faulty . |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
