Old 09-16-2022, 12:14   #1 (permalink)
Member: 2901755
Nokia c2 TA-1204 diode identify
i need a big favor. i need to identify a smd diode. its on Nokia c2 ta1204 model.. near battery pin. its codes as "B8 T " its a too small diode. plz help to identify..
File Type: jpeg WhatsApp Image 2022-09-16 at 11.52.07 AM.jpeg (151.4 KB, 10 views)
File Type: jpeg WhatsApp Image 2022-09-16 at 11.51.10 AM.jpeg (146.8 KB, 8 views)
Old 09-22-2022, 05:21   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
if you found shorted diod then you must remove that small diod , you need to check big filter chipcap beside that small diod and also check or replace big diod , R020 boosting resistor .
post result
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 09-23-2022, 04:06   #3 (permalink)
Member: 2901755
post result
i messed up with that diode. its broken now. i need to find suitable one.
Old 09-24-2022, 10:31   #4 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
ok you may found in many feature phone like samsung nokia ......
post result
Page generated in 0.20082 seconds with 9 queries
