Nokia c3-00 auto off in ring tune I have nokia c3-00 when i select ringtunes or volume its being turn off it becomes turn off in ringtunes i flashed it with latest version but still same problem FACTORY RESET FULL BUT SAME any idea plz thnx |
seems software issue (cnt problem) try to flash with another version . |
Already tried with another file |
ok , check mobile current consumption . reply . |
Consumption is perfact working |
ringer problem change speaker and post result. |
Remove vibrator 100% solution press thanks if useful for you |
I have same problem i remove vibrator set working now you try to it......................... |
change ringer and post result...... or try to check without ringer..... |
Remove vibrator 100000000000% solution press thanks if useful for you ............................anwargreat |
dear moderator plz delete this tread i got my solution |
Would you like to share your solution so others can take advantage and should not search |
change volume keys............................ |
problem solved with removing vibrator |
Remove vibrator 100000000000% solution press thanks if useful for you |
