10-21-2014, 13:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | nokia x2-01 user code problem<<<strange problem>>>> i have set nokia x2-01 qwerty keypad in simple user code. after power on mobile when i connect usb cable into mobile,a massage appear look it------ unlock security code to active usb.... it means set detect usb but it will work after unlock user code and for unlock user code we have to flash it or reset factory data. therefore when i am trying to flash it set no boot ,no sence. i tried from nokia best tool ,atf bo and hwk boxes but set not getting boot mode . i need tested solution for expert who already faced this problem. Last edited by mahzra azra; 10-21-2014 at 13:09. Reason: set name written wrong |
10-23-2014, 21:11 | #2 (permalink) | |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Quote:
Start flashing put USB cable in the cellphone and check the result! Br. | |
10-25-2014, 07:23 | #3 (permalink) | |
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Quote:
Ithout battery or with battery. By the way,i use all method for this mobile. The main reason for problem is that usb work that time when user code will bbe unloaked. It means set does not accept usb unless user code removed. Therefore i am unable to remove code. Any other solution? | |
