Old 02-03-2013, 15:01   #1 (permalink)
Registered User
Member: 1098397
Thanks Meter: 80
nokia C2-02 Not start-up problem pls help me
power on phone then white light [ keypad light ok both ] few second blank display
few second
then press call ans key, keypad light on but down keypad [up side keypad light & display light off ] [ try new strip but same ]
then press off key phone switch off
The Following User Says Thank You to palav For This Useful Post:
Old 02-04-2013, 14:52   #2 (permalink)
Registered User
Member: 1098397
Thanks Meter: 80
help me pls ...............................
Old 02-04-2013, 19:05   #3 (permalink)
Member: 608516
Sonork: 100.1607007
Thanks Meter: 123
few second
flash it with latest version flash file
Old 02-05-2013, 03:25   #4 (permalink)
Member: 1406155
Thanks Meter: 38
Jumper it from on lcd to display +point and cheqe ground also do same to other led problem solve.
Old 02-05-2013, 06:46   #5 (permalink)
deepak.'s Avatar
Member: 1825795
Sonork: 100.1621021:98
Thanks Meter: 183
hi
same problem i have few model solve after fleshing
but few model not solve by fleshing i am still searching parmanent solution .....
Old 02-05-2013, 06:54   #6 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 831
bro remove camra after that flash same problem solved with this mothed
Old 02-05-2013, 07:45   #7 (permalink)
deepak.'s Avatar
Member: 1825795
Thanks Meter: 183
hi
broo not working for me same
Old 02-05-2013, 07:58   #8 (permalink)
mehmoodtarek's Avatar
Member: 1785241
Sonork: 100.1616353:tarekkhl
Thanks Meter: 192
upload ur pcb board picture (uem +lcd cont side) then i will give an solution ,reply quick
Old 02-05-2013, 08:16   #9 (permalink)
deepak.'s Avatar
Member: 1825795
Thanks Meter: 183
hi
[IMG]**************************************/images?q=tbn:ANd9GcSvByC3XMpfxsThnf3cTYs7TT9yom-NhGNUNZiz-F5TG2tqSvfb[/IMG]
Old 06-09-2013, 20:00   #10 (permalink)
rajkumak's Avatar
Member: 1359361
Sonork: 12345
Thanks Meter: 57
few secon
only orginal strif cheng........................0k dested
Page generated in 0.17065 seconds with 8 queries
