Old 11-28-2012, 11:03   #1 (permalink)
Member: 1843214
Sonork: 100-1608030
Thanks Meter: 3
Arrow Nokia 101 White Display 100% Tested Solution
Nokia 101 White Display Problem Repairing Solutions are available in the following article. Also you will find Nokia 101 Display Ways and Jumpers information in the diagrams further in this post.
Nokia 101 White Display Solution
Nokia 101 Blank Display
Please Note that we will edit these solutions or add new ones if found in this page at any time in the future. So feel free to come back any time on this page to stay up to date.
Here Are Nokia 101 White Display Problem Solution. Please Observe Carefully.
If you have further Questions please don’t hesitate to leave a comment.
Note: Every diagram we post on *********.com is tested by one or more members of our team. Still Use them at Your Own Risk we are not responsible if these solutions may cause any harm to your phone.
GSM-FAZAL
The Following 5 Users Say Thank You to Fazal Rabi Khan For This Useful Post:
Old 11-28-2012, 11:08   #2 (permalink)
GSM-DOCTOR's Avatar
Member: 604333
Sonork: 100.1590054
Thanks Meter: 1,845
http://forum.gsmhosting.com/vbb/f148...ution-1574040/
The Following User Says Thank You to GSM-DOCTOR For This Useful Post:
Old 04-21-2013, 10:28   #3 (permalink)
Member: 772651
Thanks Meter: 1,694
The Following 2 Users Say Thank You to ajit bs For This Useful Post:
Old 05-04-2013, 17:42   #4 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 248
http://forum.gsmhosting.com/vbb/f148...ution-1568204/
Old 05-09-2013, 13:02   #5 (permalink)
nice_champ's Avatar
Member: 1082557
Sonork: 100.1611230
Thanks Meter: 199
Don't you have any new solution???
Old 06-13-2013, 08:20   #6 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
Old 06-14-2013, 07:16   #7 (permalink)
anajnisha's Avatar
Member: 1033632
Thanks Meter: 62
try to this
ImageShack® - Online Photo and Video Hosting
Old 07-25-2013, 20:54   #8 (permalink)
rajkumak's Avatar
Member: 1359361
Sonork: 12345
Thanks Meter: 57
Old 11-20-2013, 18:41   #9 (permalink)
Member: 1299469
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.650
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00000000~0x0001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 24576 bytes
Data Checksum: F5BE
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00800000~0x00BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 4128768 bytes
Data Checksum: D598
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 1697536 bytes
Data Checksum: 047E
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.65ag
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00100000~0x005E7A3E
Start Erasing...
Block Erase Done...
Data Size: 5143104 bytes
Data Checksum: CE2A
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai06.65ag
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00E60000~0x00F1803E
Start Erasing...
Block Erase Done...
Data Size: 753728 bytes
Data Checksum: BB5C
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:04:17
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 06.65 07-11-11 RM-769 (c) Nokia
IMEI: 354584053704743
Product Serial Number: 67EC476BI
Product Code : 059P7M3
Module Code : 0204874
Basic Production Code: 059P5G1
PPM SW Version : V 06.65 07-11-11 RM-769 (c) Nokia AG
ADSP Version : p V 06.65\n07-11-11\nRM-769\n(c) NMP\nag
MCU SW Version : V 06.65 07-11-11 RM-769 (c) Nokia
HW Version : 3000
UEM Version : 1328
UPP Version : 8850
LCD Version : UNKWN: IDs: 00:00:00
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000040002
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : FAILED
Phone Cannot Enter Normal Mode if LCD
is Damaged or LCD is not Properly
Connected to the Main PCB
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
OK
OK
OK
OK
OK
OK
Changing Phone Mode...
(Wait for 10 seconds)
Successfully set to : Normal
Old 11-20-2013, 18:43   #10 (permalink)
Member: 1299469
Old 12-02-2013, 03:27   #11 (permalink)
Member: 703094
Thanks Meter: 23
thanks for this diagram i use today 100% tested
Old 06-24-2014, 19:30   #12 (permalink)
rajkumak's Avatar
Member: 1359361
Sonork: 12345
Thanks Meter: 57
Old 03-21-2015, 15:34   #13 (permalink)
Member: 2363522
Cool Noika 101
thx
It,s 100% working sir
Old 05-16-2015, 06:50   #14 (permalink)
Member: 1963898
Thanks Meter: 52
Originally Posted by rajkumak View Post
Sir any sol nokia 1616 full keypad ways likesthis diagram
Old 12-13-2015, 12:35   #15 (permalink)
Member: 2268438
Sonork: 100.1667123:Flasher
help my nokia 101 LCD blank white...
The Following User Says Thank You to Ichank Fisheri For This Useful Post:
Page generated in 0.22057 seconds with 8 queries
