dear its a fake soultions,only chang power ic. |
c5 vibrate only Quote:
rehot ic not a solution bro its only flash problem flash with higher v problem slove n reply |
i think its 90% hardware fault Quote:
then give us higher ver flash files :D |
I have change power ic n reball flash cpu but still nothing........! Any solution master!!! |
C5- vibrate Only board short C5 Only Vibrate 100% Solution Rehot or Shake IC which is besides USB connector or Shake or Replace its 100% working |
hehehehe Quote:
Brother there is lots of solution, some time only reheat the Handfree ic based near with usb connector, some time, reheat the Gazoo and some time reheat the Rapuyama. So there is not 100% solution, because some time u do all but its not work, so if your set will on in these ic`s then its your good luck... |
this solution is not confirm 100% ....some mobile water damage hf ic near usb connector is shorting mobile only vibrate ...first check software if u software ok set not local mode 100% hf shorting...put paste and just shake i.c then check.....working or not working.. |
same solution i repair 10 mobile c5 .... |
hi bro i have nokia c5-03 just vibration only plz help me i flashed with letest ver but sam condition ...........give me any hrdware solution |
good solution its working |
This version of Nokia phones weak processor does not benefit those solutions in many cases, the solution must be to have a copy of the rpl and full pm then just change the flash ...........done |
this is not a good solution faq soltion i solve the c5 only vibrate solution just remove a usb ic near the usb jack ur prb 100% solve...... |
