05-05-2011, 14:48 | #7 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Troubleshooting hints for Nokia C5 memory card problem: 1. Try to use and replace another working microSD card. 2. Clean the microSD card holder if oxidized. 3. Check the VMEM voltage this reads from 1.8v to 3V. 4. Check replace the 47 ohms resistors and 18p and 100n capacitors. 5. If the above procedures didn't work, try to restore, flash update the device firmware. 6. If the firmware is okay. the possible faulty is the GAZOO IC. Reworking or replacing it will only fix the problem. |
The Following 2 Users Say Thank You to aZimBahar For This Useful Post: |
05-05-2011, 14:48 | #8 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Repair hints for not working camera on Nokia C5: 1. Remove the camera module, clean the socket or holder pins if oxidized. 2. Check the VCAM 1.8V and 2.8V on across to the highlighted filter coils and capacitors. Check/replace also those coils. 3. If the voltage is missing or there is no readings, check the VBAT 3.8 volts 4. If the VBAT voltage is okay, replace the regulator IC on a specific voltage that has no readings. 5. Replace the camera module |
05-05-2011, 14:49 | #9 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Nokia C5 keypad not responding - connection tracing repair solution [IMG]http://2.bp.********.com/_haRAPmO1Seg/TMUsqjL-J4I/AAAAAAAAAqI/JiUtlAjCVc8/s320/nokia+c5+keypad+full+ways+tracks+solution.jpg[/IMG] |
The Following 3 Users Say Thank You to aZimBahar For This Useful Post: |
05-05-2011, 14:49 | #10 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Nokia C5 Microphone Failure Repair Solution [IMG]http://2.bp.********.com/_haRAPmO1Seg/TML7MXYdNZI/AAAAAAAAApA/1rNaRT7YBgQ/s320/C5+Mic+problem+solution.jpg[/IMG] |
