03-18-2011, 16:15 | #1 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Baroda Age: 42
Member: 5871 Status: Offline Thanks Meter: 87 | Nokia c7 jumper ways Solution Nokia c7 Sim card pin connector jumper ways Solution If you are trying to fix the Nokia C7 with 'insert sim card' error problem. and having trouble finding the sim card flex board replacement, this solution may help and solved your repair problem. The solution below provides the connection line paths of the Nokia C7 sim card slot or flex board, that is useful for applying a jumper remedy on an open or cut off connections. Just refer to it and trace each of the sim card pins, then just managed to apply a jumper wire on it. Applying a jumper wire on it is a little bit tricky but so easy, just use a magnifying glass to ensure the quality of solder and avoid short circuit. |
03-18-2011, 16:18 | #2 (permalink) |
Member: 5871 Status: Offline Thanks Meter: 87 | Nokia C7 Touch Screen Problem Solution Nokia C7 Touch Screen Problem Solution This solution may help for hardware repair on Nokia C7 with not working touch screen problem. If the touch screen digitizer is broken or cracked of your Nokia C7, you may only need to replaced it with a new touch screen glass digitizer. Just look for nokia C7 disassembly guide to properly dismantle the phone. This may help if the touch screen digitizer is not damaged or already been replaced but still it doesn't respond. Try to check out the solution below and check the higlighted components, it is the basic parts where to check or replaced. Check the touch screen panel assembly for possible damaged, cracked or broken. Check the touch screen flex cable, there is an IC mounted on it. managed to rework it. If the touch screen still doesn't work, check the pin connector, clean if oxidized. Check or replace the resistors coils and capacitors. |
07-12-2011, 21:20 | #7 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Hi, I'm looking for advices to change a charging connector on a c7, like links for disassembly or tricks to make this job easier and more efficient. Thanks to all ! |
The Following User Says Thank You to cycofcgb For This Useful Post: |
08-04-2011, 08:18 | #8 (permalink) | |
Freak Poster Join Date: May 2008 Location: The Time Has Come....
Member: 765331 Status: Offline Thanks Meter: 78 | Quote:
Here the link bro... ‪Nokia C7 | |
12-14-2011, 16:30 | #10 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: MUMBAI INDIA Age: 35
Member: 697969 Status: Offline Thanks Meter: 8 | Quote:
12-15-2011, 15:08 | #13 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: Perm
Member: 383424 Status: Offline Thanks Meter: 24 | Quote:
If this not help u - try check two this roads from Resistors, is other side near plug in | |
