11-05-2012, 18:57 | #2 (permalink) |
Freak Poster Join Date: May 2012 Location: dubai Age: 38
Member: 1766383 Status: Offline Sonork: [email protected] Thanks Meter: 4 | wath you want brother show in pic then i can solve your broblim |
09-14-2013, 17:40 | #6 (permalink) |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | c7 touch not working Initializing Tests... IMEI : 357395046328202 , Phone : RM-675 Nokia C7-00 Get keys... PASSED | ST_SLEEP_X_LOOP_TEST PASSED | ST_UEM_CBUS_IF_TEST PASSED | ST_EAR_DATA_LOOP_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_KELVIN_BATVOLTAGE_TEST PASSED | ST_KELVIN_VIBRA_TEST PASSED | ST_KELVIN_CAPACITOR_TEST PASSED | ST_KELVIN_MISC_TEST PASSED | ST_KELVIN_AUDIO_TEST PASSED | ST_KELVIN_XEAR_TEST PASSED | ST_USB_CHARGING_TEST PASSED | ST_DIGIMIC_TEST PASSED | ST_LED_CONTROLLER_TEST PASSED | ST_AUDIO_PLL_TEST PASSED | ST_RAM_IF_TEST PASSED | ST_CDSP_SLEEPCLOCK_FREQ_TEST NOT EXECUTED | ST_CDSP_RF_BB_IF_TEST NOT EXECUTED | ST_CDSP_STROBE_TEST NOT EXECUTED | ST_CDSP_DIGI_RXTX_IF_TEST NOT EXECUTED | ST_CDSP_RF_SUPPLY_TEST NOT EXECUTED | ST_CDSP_PA_ID_PIN_TEST NOT RUN | ST_CDSP_WCDMA_TX_POWER_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_CAMERA_ACCELERATOR_TEST PASSED | ST_SEC_CAMERA_IF_TEST ->ERROR | ST_LED_FLASH_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_MAIN_LCD_IF_TEST ->ERROR | ST_TOUCH_TEST ->ERROR | ST_TOUCH_IF_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_WLAN_TEST PASSED | ST_MASS_MEMORY_IF_TEST PASSED | ST_ACCEL_IF_TEST PASSED | ST_VIBRA_TEST NOT RUN | ST_USB_LOOP_TEST PASSED | ST_MAGNETOMETER_TEST PASSED | ST_USB_CHARGER_TEST PASSED | ST_LED_FLASH_IF_TEST PASSED | ST_NFC_TEST ->ERROR | ST_NFC_ANTENNA_TEST PASSED | ST_PROXIMITY_TEST SelfTests end here is seft test all touch track r ok |
09-15-2013, 11:41 | #7 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
1. self test of the above I conclude that the working voltage of its touch screen Her second check working voltage on C7582 and C7583 .... data path and clock its touchscreen R2441-R2441 and R2443 ... its value is very small ... if broken will affect the touchscreen 2. try to replace the board change its flexi touch ui (alternative ending) see the picture below dont forget to press thank | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
