11-13-2002, 16:32 | #1 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Mongolia
Member: 4034 Status: Offline Thanks Meter: 0 | new N6210 network first going on then dropped I have strange problem in 6210, 3310 3330 phones. After turned on the network is full then passed few seconds it is dropped. after that never found network. I changed the software, ID, hardware chips in RF circuit but no success. Any idea or solution for it, Please, advice me. Best wishes, Ganaa [email protected] |
11-14-2002, 17:50 | #4 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | dgtulga now, you have to measure phone ! first, you use oscilloscope , to see TX IP/QP from COBBA to Hager, see that wave all correct ? and check TXP and TXC ! and you use multi meter ( or oscilloscope ) to test VTX , and VCP and all Vxx for Hager and use wintesla to set TX power level on 5, and measure that PA out going is working at 32bdm or not then check TXDET path to Hager ! then check Antenna ! Willy Quote:
11-14-2002, 18:02 | #5 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Philippines Age: 47
Member: 4873 Status: Offline Thanks Meter: 5 | hi willy, i usually just check tx via netmonitor.. I'm already beginning to be good at it in 33, 8x, 62... not quite on 51 and 32 II want to know if these works on cracked wintesla? I have read your previous posts and reqad the manual(Wintesla Manual) but still get and error... or can we tune the phone after replacing "major" ic's on cracked wintesla? I want to give the phone at its best state not just "With Network" |
11-14-2002, 18:29 | #6 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | trafix,, why not you use get one PKD-1, and save your all wintesla problem , since it is not expensive ! and cloned already for sell ,,, ( ask spear)! netmoniter is helpful ,, but it can not tell you, that which parts is "dead" ,,,, you only can know,, how is RX, and TX (yes or no) ! measure phone is correct way to do it if you interested, i can teach you in my office ,, just mail me ! Willy |
N70... on then network come out it (hang)? | jimmyyew | Nokia Hardware & Hardware Repair | 0 | 11-29-2006 11:06 |
3310 can make call, then no RF at all then RF CAN go up then down again | Burnt Cobba | Nokia Hardware & Hardware Repair | 3 | 06-18-2003 21:39 |
8210 Network is Up & then Drops. | mobilerocks | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-19-2002 17:36 |
3310 power on then 1-2 sec lost network | hs_ | Nokia Hardware & Hardware Repair | 8 | 10-26-2002 23:15 |
