Old 01-05-2007, 13:44   #1 (permalink)
Member: 200634
Thanks Meter: 41
3100 Erasing Problem
dear experts
i have a dead 3100
it show 1st boot ok in ufsx
but when i want to flash it it show the erasing error
1st Boot Ok, DCT4, UPP: 1120
Fl0: 0x01000000-0x01FFFFFF,90797FA4,
Algorithm: u_intel.fia, Ver: 4.49.0
Algorithm Ok, MSID: 8451D876CF1253D9D3076A0933
Decoded MSID: 8FA4BAE9-0054E6E9-A8000000
Encoded FAID: 2E3E9522-F78C2F59-509C7AB8
Erasing: 0x01000000-0x0100FFFF ...
Erasing Error: 10, at: 0x01000000-0x0100FFFF, 940207, Time: 00:00
Process Failed, Repowering Mobile
i reball the flash ic and UPP also the problem is still remain
pls experts help me solve this problem
Old 01-05-2007, 17:38   #2 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
Flash IC still the problem mate... do it again, apply good flux to Flash IC reheat your ic not good contact @ the board.
Old 01-05-2007, 20:28   #3 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
Thanks Meter: 408
first reball cpu... if dont work than reball falsh....
Old 01-06-2007, 02:47   #4 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
change flash ic,ur problem is 100% solved.
Old 01-06-2007, 12:32   #5 (permalink)
Member: 200634
Thanks Meter: 41
if i change the Flash IC,
can i want to change the UEm also
Old 01-06-2007, 17:58   #6 (permalink)
~mr_Ten$ion~'s Avatar
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
Change Flash UIc & then Full Flash ........... No need Change UEM .... Thanz
Old 01-06-2007, 20:10   #7 (permalink)
Member: 275631
Thanks Meter: 408
can u explain breifly ... how can v change flash without changing uem in dct4
Old 01-27-2007, 08:54   #8 (permalink)
Member: 248765
Yes, No need replace UEM. Just Flash with proper firmware, write flash Rpl ,write PM, and unlock. Phone will be ok
Old 01-27-2007, 09:40   #9 (permalink)
Gsm_pro's Avatar
Member: 292599
Thanks Meter: 66
Check fia file from phoenix,if ok try erase again...
Or flash IC probem..
Old 01-27-2007, 11:37   #10 (permalink)
jaggi's Avatar
Member: 258480
Thanks Meter: 14
reball flash ic flash with jaf if not work then change ur flash ic firt erase full flash then flash normally 100%%%%%%%%%% solved
Old 01-27-2007, 23:31   #11 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
no all of you with very sorry no idea just flash set with Mt-box by disable vpp method and all will be 100000000000000000% ok this error remove with MT-box nicely with out any changes sorry to all of you my brothers
Old 01-27-2007, 23:33   #12 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
in this error specialy Mt-box only help and other all failed
3100 Erase Failed celluniversal Nokia Digital Core Technology 4 ( DCT-4 ) 17 07-09-2007 02:43
need 3100 erase file HUM Nokia Hardware & Hardware Repair 2 12-24-2006 07:42
i need 3100 erase file kardelen gsm Nokia Digital Core Technology 4 ( DCT-4 ) 0 04-16-2005 10:18
i need 3100 erase file kardelen gsm Nokia Digital Core Technology 4 ( DCT-4 ) 0 04-16-2005 08:59
3100 charging problem... hrco Nokia Hardware & Hardware Repair 1 12-06-2003 06:51
Page generated in 0.28693 seconds with 9 queries
