06-27-2013, 06:05 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | C1-01 just vibrate & blink then nothing help me if anybody knows how to solve this problem Code: Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.37_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm607__03.35.mcusw Image : rm607__03.35.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:11 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:35 ===Flashing [PPM]=== File : 5FC9E6E8_rm607__03.35.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:19 Write , Start : 0x41C00000 , Len : 0x00319A48 Flashing , wait ... Region flash done, time : 00:00:03 ===Flashing [CNT]=== File : 4332348D_rm607__03.35_001.image_m_c_ctv_pk_9g897 Image : /0_Synergy/Projects/rm607_sw_settings/temp/059G897/CONTENT_CO Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:33 Write , Start : 0x42200000 , Len : 0x00B20000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip Flashing done! Total flash time : 00:05:22 Reboot phone now... - > AfterFlash Failed! :( Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy |
06-27-2013, 06:39 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Dadu Sindh Pakistan Age: 37
Member: 1322713 Status: Offline Sonork: 100.1663786 Thanks Meter: 254 | Dear flash it with lattest version......... if still same condition then chek in hardware rehot normaly flash ic............ |
06-27-2013, 06:51 | #3 (permalink) |
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | already I did it reball flash chip & cpu after that flashed with 6.07 problem same phone doesn't enter to local mode when try to power on it just vibrate & blinks |
06-27-2013, 11:59 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2011 Location: APPEL
Member: 1707492 Status: Offline Thanks Meter: 606 | dear brothers flow ... me chik ..1 battery terminal ways medal pin ... and like to same code and flash . and last remove usbe ic and port . |
The Following User Says Thank You to MATELECOM1 For This Useful Post: |
06-27-2013, 19:07 | #7 (permalink) |
Freak Poster Join Date: Nov 2011 Location: GSMHOSTING
Member: 1691378 Status: Offline Sonork: 100.1645448 Thanks Meter: 141 | JUST CHECK THE PRODUCT CODE FROM BACK AND DOWNLOAD THE EXACT PRODUCT CODE FIRMWARE AND FLASH IT.USE NOKIA CARE SUIT TO DOWNLOAD FIRMWARE Sent from my GT-I9003 using Tapatalk 2 |
