Old 06-03-2009, 11:57   #1 (permalink)
.::PATEL TELECOM::.'s Avatar
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
nokia e71 problem
hello sir,
i have problem with nokia e71
in e71 when i power on my handset without charger it is not start but when i attech charger than power on phone
so what is problem sir plese give some information
thanks in advance
The Following 3 Users Say Thank You to .::PATEL TELECOM::. For This Useful Post:
Old 06-12-2009, 11:00   #2 (permalink)
Member: 5202
Thanks Meter: 7
I have the same problem???
Did u found the solution for repair????
Regards....
The Following User Says Thank You to gabrielgsm For This Useful Post:
Old 06-12-2009, 11:06   #3 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
Regards....
no frind i can't find solution
anyone solution pleseb help
thank you
The Following User Says Thank You to .::PATEL TELECOM::. For This Useful Post:
Old 10-24-2009, 07:20   #4 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
hello can anyone have this problem's solution please help for this problem still having this problem
masters please help
Old 10-24-2009, 07:27   #5 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
Originally Posted by .::PATEL TELECOM::. View Post
hello sir,
thanks in advance
check power way may its missd
with charger when u atach the set is atumatic on and show charging and with out if power way is miss so its can,t power on so check power way
Guljee
The Following 2 Users Say Thank You to guljee786 For This Useful Post:
Old 10-24-2009, 07:31   #6 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
hello sir,
thanks in advance
any deteil any more fore this st?
Guljee
Old 10-24-2009, 07:45   #7 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
set is ok and fresh not water damage i open set but all ics part are silding
some times it can power on and some time not without charger
Old 10-24-2009, 07:49   #8 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
bro r u check ur bettry mostly its bettry problem
Guljee
Old 10-24-2009, 07:50   #9 (permalink)
Member: 457470
Thanks Meter: 159
resolder the power switch. check with another battery. or usb phone power cable
Old 10-24-2009, 07:52   #10 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
i all chack but same problem
Old 10-24-2009, 07:55   #11 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
ok bro r u check power switch must its water damg plz clean and resold and try if not so also try in soft and riply..
some time off some time on mostly if power is water damg then its creat this problem
Guljee
Old 10-24-2009, 08:00   #12 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
i try in soft but same problem
if u have its good pm file plese upload here
thanks
Old 10-24-2009, 08:53   #13 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 422
thanks
brother there is a very few chance in software
1>when u press power on button without charger did ur handset show any light or nothing?
2>and with charger handset get automatic on or it needs to press power on?
Old 10-24-2009, 10:09   #14 (permalink)
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
nothing happen when i press power on butten without charger and with charger first charging bar coming than when i press power butten than phone is became on
Old 10-24-2009, 10:16   #15 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
(((( PATEL if u have its good pm file plese upload here
thanks))))
rm............?
493?
Nokia E71-2 rm-357 problem mtechstation Nokia Base Band 5 ( BB-5 ) 4 06-23-2014 12:17
nokia E71 TIM unbranded - keyboard problem ovidiux Nokia Base Band 5 ( BB-5 ) 11 04-26-2009 18:25
Nokia E71 UMT Problem wizardofwaz Nokia Hardware & Hardware Repair 0 02-26-2009 14:18
Nokia E71 SMS sortind date problem mikes511 Nokia Multimedia 0 12-28-2008 17:36
Unlocking problem with Nokia E71 munir0410 Universalbox 3 11-13-2008 13:33
Page generated in 0.27314 seconds with 10 queries
