12-09-2008, 22:25 | #1 (permalink) |
Junior Member Join Date: Aug 2008
Member: 833371 Status: Offline Thanks Meter: 1 | Nokia N70 problem I removed memory card format phone using this code *#7370#and nothing ! |
12-10-2008, 06:34 | #3 (permalink) | |
No Life Poster Join Date: May 2007
Member: 515972 Status: Offline Thanks Meter: 526 | n70 Quote:
try this http://rapidshare.com/files/17196743...ution.JPG.html | |
12-10-2008, 17:04 | #6 (permalink) | |
Member: 833371 Status: Offline Thanks Meter: 1 | This page needs JavaScript, to display all information correct! Error This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times. This limit is reached. To download this file, the uploader either needs to transfer this file into his/her Collector's Account, or upload the file again. The file can later be moved to a Collector's Account. The uploader just needs to click the delete link of the file to get further information. Quote: | |
12-10-2008, 18:31 | #7 (permalink) |
Junior Member Join Date: Oct 2008
Member: 882232 Status: Offline Thanks Meter: 1 | yes it is slow but if you can make call, send messages thats fine. the last time i fix n70m, i flashed it, upgraded the firmware, and ic zukus failure happened. so i replaced ic zukus( yes only 1 ic ) and tried jumper those 4 resistor. and worked but still when i check for any shorting ( the negative to positive and vice versa) with multimeter, i found there is shorting. but n70 is running till now, i am happy. try flash it first. but with newer version. beware that bb5 CAN die if downgrade. i am junior. i just want to help. i am sorry for any mistake. |
05-15-2012, 14:11 | #11 (permalink) |
Registered User Join Date: Dec 2009 Location: HABARADUWA - Sri Lanka Age: 39
Member: 1179630 Status: Offline Sonork: 100.1644820 Thanks Meter: 80 | I Have 2 sets ... Same Problem.. Both Drop Damage.. Flash & SMPS Jumper Not Working I think some data line missing Now I'm Try change Clock cryslal If it works i post here |
Nokia N70 Problems | klorel | Nokia Base Band 5 ( BB-5 ) | 4 | 10-20-2010 08:27 |
nokia n70 problem | mr.bilal ahmad | Nokia Hardware & Hardware Repair | 13 | 05-20-2009 07:46 |
Nokia N70 problem | fareedreg | Nokia Hardware & Hardware Repair | 9 | 12-09-2008 11:48 |
Nokia N70 problem unlock | said4 | HWK | 0 | 02-01-2008 07:06 |
