07-08-2008, 18:52 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 340774 Status: Offline Thanks Meter: 164 | nokia n72 keypad problem |
The Following User Says Thank You to vinkle For This Useful Post: |
07-08-2008, 19:38 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Roumania
Member: 461923 Status: Offline Thanks Meter: 2,020 | ..no keypad problem..your phone freez...possible OMAP problem..but frist try full flash + format then clean very good PCB..with ultrasonic cleaner if possible... |
07-08-2008, 20:14 | #4 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Australia
Member: 740993 Status: Offline Thanks Meter: 75 | hello brother when keypad stop works then check is phone is still able to receive call if yes then it means phone problem is in keypad section otherwise phone gets hang then try with flash ,,,' b.r. smartengghelp |
The Following User Says Thank You to smartengghelp For This Useful Post: |
07-08-2008, 20:31 | #5 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: bahrain
Member: 734871 Status: Offline Thanks Meter: 1,348 | Quote:
check camera swich first. thanx. | |
12-03-2008, 15:05 | #8 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 360614 Status: Offline Thanks Meter: 63 | My N72 all the keypad are not working. I changed keypad ic, changed small ic near key connector, changed keyboard, format, removed camera and memory key but no success. The board is fresh and i can on/off the phone. Also i checked voltage in keyboard, it showed 1.7v but why is it not working? |
NOKIA N72 keypad light goes after booting | ameerali19 | Nokia Hardware & Hardware Repair | 9 | 05-05-2010 18:54 |
n72 keypad problem | aryan_ | Nokia Hardware & Hardware Repair | 16 | 08-25-2009 17:26 |
N72 keypad problem | shok9992000@yah | Nokia Hardware & Hardware Repair | 3 | 03-07-2008 16:14 |
n72 keypad problem | smartengg | Nokia Hardware & Hardware Repair | 0 | 12-22-2007 10:56 |
n72 keypad problem (different) | raj_cxe | Nokia Base Band 5 ( BB-5 ) | 1 | 10-25-2007 07:38 |
