Old 03-09-2011, 05:41   #1 (permalink)
Member: 649475
Thanks Meter: 17
Nokia N73 not powering on
hi mate,i changed batt. connec. of NOKIA N73 woking and after it ,it became dead.I flash it ,it flashed very well and powering on in normal mode but not powering on very well
pls help.......................
Old 03-09-2011, 05:53   #2 (permalink)
krishnadas.g's Avatar
Member: 836786
Sonork: 1,009 horrold
Thanks Meter: 48
bro chance to bsi
so agine change or refix battery conector
Old 03-09-2011, 06:09   #3 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,454
bro with cable phone power on
try to connect charger then check charging show or not
no show charging u can check battery connctor
post result
Old 03-09-2011, 06:38   #4 (permalink)
Member: 649475
Thanks Meter: 17
post result
sir whn i connect chg. it shows NOKIA and turns OFF
Old 03-09-2011, 06:42   #5 (permalink)
Member: 1000479
Sonork: 100.1638119
Thanks Meter: 52
hi
bro if charging is ok check power switch
Old 03-09-2011, 06:43   #6 (permalink)
Member: 351924
brother what is the first condition in this handset?
dead or trun off problem?
u flashed lastest version?
Old 03-09-2011, 06:51   #7 (permalink)
Member: 649475
Thanks Meter: 17
sir set was totally ok only b/c was dusted
and i flashed with ths ver. N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx
Old 03-09-2011, 06:57   #8 (permalink)
Member: 351924
bro with battery what is the condition?
Old 03-09-2011, 06:58   #9 (permalink)
Member: 649475
Thanks Meter: 17
with b/c was too okkkkkkkkkk
Old 03-09-2011, 07:04   #10 (permalink)
Member: 649475
Thanks Meter: 17
now with batt. not powering on
Old 03-09-2011, 19:06   #11 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
just solder your battery connector ground pin in board ground.
today i tested.
The Following User Says Thank You to net.tarik For This Useful Post:
Old 10-15-2011, 17:35   #12 (permalink)
Member: 289307
Thanks Meter: 44
post result
Old 03-30-2013, 10:14   #13 (permalink)
Member: 1905906
Thanks Meter: 3
hwk box auth error 20 solution
Old 03-30-2013, 12:44   #14 (permalink)
zubair pathan1's Avatar
Member: 1867883
Sonork: 100.1654594
Thanks Meter: 27
check power swich.................
Old 03-31-2013, 11:40   #15 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 248
fist chack the bsi line and power key track....
flashing with ufs.....then post the result...
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.17134 seconds with 8 queries
