02-14-2013, 15:16 | #1 (permalink) |
Registered User Join Date: Mar 2010 Location: india Age: 38
Member: 1262367 Status: Offline Sonork: muhammedshafikulangaredat Thanks Meter: 19 | Nokia n73 security test failed MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0830AA1 Using device: HTI, FW ver: 00.50, SN: 00012CF5 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 4CE28438D135FCC03883DC781A607BE9A94DC0FB ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B21 PUBLIC ID: 1D200218C29F01544EF118BB9CADE3FE3DBDD6AA ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 Storage0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: FLASH,NAND, asic:APE Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Original Imei: 35364001638737 Original Product code: 0529785 Bluetooth ID: 001979D6106A SIMLOCK PA identifier: [0] PA_SL Phone type: RM-133 (Nokia N73) SW version: V 05wk47v61 09-07-08 RM-133 (c) Nokia. Imei plain: 35364001638737-1 Product code: 0529785 Battery voltage: 4020 mV, current: 146 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353640016387371 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
02-14-2013, 15:20 | #2 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | I try to repair by this solution 100% work 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) wbr ; tejaram |
The Following User Says Thank You to .::TEJARAM::. For This Useful Post: |
02-14-2013, 17:55 | #3 (permalink) |
Crazy Poster Join Date: Jun 2011 Location: Colombo
Member: 1605843 Status: Offline Thanks Meter: 7 | Yes this solution is correct. But I think the last step almost enough to solve this (6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) |
The Following User Says Thank You to dhanushkadx For This Useful Post: |
02-14-2013, 17:56 | #4 (permalink) |
Member: 1605843 Status: Offline Thanks Meter: 7 | Hope you also like ths .::Solution / Information ::.. about SL3 Contact Service Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 35322303439634-2 Product Code: 0577793 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353223034396342 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF how can i repair this error ? Just Do normal SX4 than write PM1 and PM309. Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 35322303439634-2 Product Code: 0577793 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed [COLOR="rgb(255, 0, 255)"]SECURITY_TEST failed![/COLOR] Imei net: 353223034396342 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF how can i repair this error ? Just Do normal SX4 than write PM1 and PM309. ( don't care about Simlock invalid as all BLOCK are open SL data not corrupted) Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 35322303439634-2 Product Code: 0577793 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed SECURITY_TEST failed! SL data Corrupted How can i repair mobile in this state? No. u can,t repair this state of mobile as SL data is corrupted too. If u have Full RPL backup with Mxkey that yes . If no than Only Nokia RPL service is the solution. Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 123456754321-? Product Code: 0577793 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! imei invalid or plain SIMLOCK invalid SUPERDONGLE_KEY seems to be invalid mobile power off after 3 mins CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed SECURITY_TEST failed SL data Corrupted How can i solve this Error? U can't repair the imei of the mobile for that u have to use Nokia RPL service. but u can get this mobile out of contact service. Last edited by dhanushkadx; 02-14-2013 at 18:02. |
02-14-2013, 18:05 | #5 (permalink) |
Member: 1605843 Status: Offline Thanks Meter: 7 | If SL3 If Only this section damage then you can solve Contact Service SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! & for this not possible SIMLOCK seems to be invalid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed |
02-15-2013, 05:58 | #6 (permalink) |
No Life Poster Join Date: Oct 2012 Location: india
Member: 1825795 Status: Offline Sonork: 100.1621021:98 Thanks Meter: 183 | hi if u have atf box just visit this page and watch video for nokia n73 http://forum.gsmhosting.com/vbb/f609...asher-1126748/ gud luck |
