07-12-2009, 10:46 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Age: 39
Member: 18577 Status: Offline Thanks Meter: 4 | Nokia N82 Memory Card Problem I've a strange problem with an N82. When a memory card is inserted in the phone, it gets detected and files are accessed properly but only for a few minutes, then the phone is unable to detect the card. Even if I try putting the card in and out several times, the card won't get detected. After leaving the phone switched off for a few hours, the card would get detected by itself, work normally for a few minutes and then again won't get detected. I've replaced the IC, but the problem still remains. I've tried switching phone on and off with MMC but still no help. I would appreciate if someone can suggest what could be the problem. The phone is running the latest firmware. Thnx Ayush |
07-12-2009, 13:20 | #3 (permalink) |
Member: 18577 Status: Offline Thanks Meter: 4 | Hey, Thanks for the reply there. I've already replaced that IC however the problem is still there. I'm not sure what to do with those small resistors over there, but my understanding is the IC should have solved the problem but it didn't. What else could be the reason for this strange behavior. Thnx Ayush |
12-17-2009, 15:37 | #11 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Mumbai
Member: 434631 Status: Offline Thanks Meter: 77 | N82 mmc ic Nokia N82 mmc ic is very common in market. u can get this ic in 6300 keypad is same in n82 mmc ic Enjoy . |
The Following User Says Thank You to tlnadar For This Useful Post: |
12-18-2009, 17:06 | #12 (permalink) |
Junior Member Join Date: Apr 2007
Member: 486214 Status: Offline Thanks Meter: 6 | jumper for n82 mmc problem http://h1.ripway.com/farhad835/n82mmc.jpg |
The Following 5 Users Say Thank You to farhad835 For This Useful Post: |
07-08-2012, 20:29 | #13 (permalink) | |
Junior Member Join Date: Jan 2008 Location: iran
Member: 678617 Status: Offline Thanks Meter: 2 | Quote:
good luck | |
07-08-2012, 20:45 | #14 (permalink) | |
these are same in package only. you are absolutly cant use 6300 keypad ic instead of n82 mmc ic and if anyone use this method it can hurt the menelaus ic(N4200). and at last you can find this ic on N95 only and no any other nokia yet. good luck skymobile | |
Nokia 6300 Memory Card Problem | .:SUBRATA:. | Nokia Hardware & Hardware Repair | 24 | 12-10-2011 13:27 |
nokia n82 memory card corrupted | logicriyas | Nokia Base Band 5 ( BB-5 ) | 1 | 02-01-2011 06:00 |
nokia 6233 memory card problem | .::Moby World::. | Nokia Hardware & Hardware Repair | 1 | 03-11-2009 14:59 |
nokia 3230 memory card problem | abrarmultani | Nokia Hardware & Hardware Repair | 1 | 04-18-2008 14:30 |
