03-01-2014, 11:42 | #1 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1976478 Status: Offline Thanks Meter: 3 | Nokia n95-1 avilma ic broken traces This is caused by the luck of my experience removing the ICS I can still save my N95? Anyone can help routing rines in the motherboard? |
03-07-2014, 01:57 | #2 (permalink) |
Member: 1976478 Status: Offline Thanks Meter: 3 | Ok i have started. After hours and hours beating out the crack out of me.Keep reading and learning...Cause iam CRAZY about elecronics I have found maping of the IC numbers and letters. So one of the broken trace i broke when removing the solder with wick ( to much heat and presure removed the trace from the motherboard) ITS THE TRACE L11 THAT GOES TO THE BATTERY BSI HERE IS THE DIAGRAM.ANY CHANGE TO RECREATE THIS BROKEN TRACE ?? and make the LINE WORKABLE AGAIN? OR ROUTING IT SOMEWHERE ELSE? Hmmm maybe i can routing it with a SILVER HAIR OF CABLE WIRE.iTS ON THE EDGE OF THE IC MAYBE IT WOULD BE POSSIBLE TOO ROUTE IT. Last edited by kon.electronics; 03-07-2014 at 02:06. |
07-02-2014, 12:08 | #4 (permalink) |
Member: 1976478 Status: Offline Thanks Meter: 3 | hi guys i have made mistakes on this.. After lifting the avilma up i started cleaning the pads of the motherboard. I destiried this lines.. L1...LST comand F1...XEarRC comand K11...Vbat2 comand K2...SimDetX comand E2...XEarLC comand I would be gratefull if someone could show me how to jumper all this broken tracks under the avilma... Just one or two if nessecary to start up the phone... Thanks guys of the greatness of people here |
07-02-2014, 21:49 | #6 (permalink) |
Member: 1976478 Status: Offline Thanks Meter: 3 | thanks for your kind answer..I know K11 its something like main suply... But i need jumpering knowledge.. I know i should solder a wire on K11 line before broken pin but i dont know the other line to make jumper Can you help me on that please? |
07-02-2014, 22:38 | #8 (permalink) |
Member: 1976478 Status: Offline Thanks Meter: 3 | hello my freind HUM. I work desperate to learn electronics.I have started from zero. ...Thanks for your great effords ..Iam deeply thankfull i still dont know something simple you say... What do you mean "+side"my friend? |
07-02-2014, 22:44 | #10 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | c2225 cap has 2 sides one side is ground and other side is plus hope u understand now |
The Following User Says Thank You to HUM For This Useful Post: |
07-03-2014, 11:24 | #12 (permalink) |
Member: 1976478 Status: Offline Thanks Meter: 3 | Hi HUM Yesterday on 5 o clock in the morning i did some progress Click photo on the link.Its from my microscope and tell me what you think View image: Picture 005 |
07-03-2014, 12:36 | #13 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | put one probe on that scratched point and thd other probe on c2225 , if meter show 1 or full beep than it mean u still have k11 pin, and with soldering wire make this founded point thick ,so when u put ic back it easily interact with that point |
07-05-2014, 00:05 | #15 (permalink) |
Member: 1976478 Status: Offline Thanks Meter: 3 | you help its outstanding and motivates me. i told you when i conect phone to power suply it goes to 0,4 ampere and when i left power button goes and stay at o,2 ampere...could this be the G2200 which missing?.. Yes thats the point you have in circe and not mine!!!!!!!! I tried to put some solder on this and extend a bit solder to the empty hole with low temperature from the point you are showing.I did it and i got the results with the power suply i told above... I will try to fing the G2200 and i will post results. The journey is going on |
