09-17-2008, 11:47 | #1 (permalink) |
Junior Member Join Date: Dec 2004 Age: 41
Member: 100521 Status: Offline Thanks Meter: 3 | Nokia N95 keeps hanging and restarting till battery is removed using camera internet browsing applications installing(SIS C++ written apps) launching some applications watching movie opening gallery ! operating so fast !!! (moving in menu and etc...) and many others things by the way, Wifi and GPS work fine ! and some java apps can be installed and worked like ExtGPS " I've flashed it with cable and flashbox both to latest firmware version(RM-159-> V21.0.016) I've formatted the phone with 3 *** damn keys !!! I've removed SIM card and MicroSD card to check'em out I've experienced those results in battery connected and charger connected both I opened the case and searched for some physical problem and some piece of metal between IC legs or other stuffs on the board and tried to brush the board to make it clean if any shortage is happened. Phone is not dropped or wet before and there's no battery problem I disconnected the 5MP camera cause I was suspected about it " ... and nothing changed Now listen !!!! "ALL OF THE PROBLEMS GONE AFTER I PUT THE PHONE INSIDE A FREEZER FOR 5 MINUTES AND IT GETS VERY COLD AS ICE AND IT KEEPS WORKING ABOUT HALF AN HOUR TILL IT GETS WARM AGAIN IN ROOM TEMPERATURE!!!!!!!!" 1)Can any one tell me what's exactly the problem about my N95 and how can I solve it and which part should be repaired or replaced ? 2)Use the cooling trick about your hanging phone and share your results here please |
The Following 2 Users Say Thank You to reza_243 For This Useful Post: |
09-17-2008, 18:07 | #3 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | There must be a problem with one ic that gets hot (if is the processor I don't thik that you have any chance to change it)...try to clean the PCB with a ultrasonic cleaner maybe the phone was wather damaged |
09-17-2008, 18:21 | #4 (permalink) | |
Member: 100521 Status: Offline Thanks Meter: 3 | Quote:
non of ICs was warm and sensed no heat on board I'm really confused P.S tonight I got GPS and RadioFM modules shield cover (that metal paper with holes) ain't there !!! should I be suspected about it ? | |
10-03-2008, 14:29 | #6 (permalink) |
Junior Member Join Date: Jun 2007 Location: india
Member: 535530 Status: Offline Thanks Meter: 10 | HELLO Every1 i solve my n95 auto restart hanging problem.nokia n95-rm159 auto restart big problem's simple solution.Problem occurrence is highly temperture dependent and can be analysed by altering temperature.problem can be fixed by soldring 2 caps(3.2pf) on PWB.After donig that i surprise my n95 100%%%% working OK .how just see this link http://www.geocities.com/deep_produc...lution.pdf.pdf [url] If you asking any question email me [email protected] |
The Following User Says Thank You to kuldeepsingh For This Useful Post: |
10-06-2008, 03:58 | #7 (permalink) | |
Junior Member Join Date: Jul 2007
Member: 555492 Status: Offline Thanks Meter: 1 | Quote:
Where i can find this 2 capasitor (3.2pf) ?? | |
The Following User Says Thank You to chipichawa For This Useful Post: |
N95-1 Hang and Restart Done by HWK | waynePH | HWK | 0 | 07-08-2009 04:30 |
n95 8g cant revive only hang and restart | bady | Nokia Base Band 5 ( BB-5 ) | 1 | 06-25-2009 06:04 |
nokia n95 rh-159 hangs and restart | astana2007 | J.A.F. By Jafsupport.com | 5 | 11-08-2008 12:02 |
My X-8 keep hanging And Restarting | papanono | Sagem Hardware Repair Area | 0 | 03-09-2007 19:33 |
