Nokia n95 not switching on Hello Here I have nokia n95 which doesn't turn on at all. The battery is ok as I checked other battery. I disassembled the phone and seems allright. When connecting via fbus cable to Jaf, phone turns on and works- but when try to use with battery I can't turn on the mobile phone. Can somebody help? |
if ok then replace avilma. |
Could you explain clearer- where avilma is? |
left side in b.c dear, left side in simtray |
I found it, but how to know if that's the fault? And How to replace it? |
http://img136.imageshack.us/img136/5464/avilma.jpg |
Check this methode dear, press power button ,then u check out put voltage v.core(1.8v),v.io(1.8v),v.aux ,this volatges ok ,u check slw,,,,,post the result..... |
any soulation>>>>>>>>>>>>>>>>>> |
What tool can I use to check the voltage? I'll have to buy one |
pls u purchace one digital multimeter |
I decided to buy a mobo hence I'm not sure. The cost of mobo is 32 pounds The cost of multimeter and avilma is about 20 pounds and I'm not sure if it solves. |
I decided to buy a mobo hence I'm not sure. The cost of mobo is 32 pounds The cost of multimeter andavilma is about 20 pounds and I'm not sure if it solves. THANK YOU ALL !!!! YOU ARE GREAT !!! |
Mobo bought and guess what? Most of the mobo components(mainly switches) bought are lost(desoldered from the board).Don't you even try allegro website-keep away it's like area 51. To reball honestly in NI I don't see anyone. 35 pounds lost. Problem still not solved. But anyway thanks for your help:cool: |
