Old 09-24-2010, 16:36   #1 (permalink)
jakkarzoya_2511's Avatar
Member: 613242
Sonork: 100.1626311
Thanks Meter: 645
Red face C5 rm645 restart problem help
I HAVE C5 WHEN I START IT SHOW MEMORY FULL AND GO RESTART , I HAVE FLASHED IT 3 TIME ON ATF ALSO TRY WITH USB AND MXKEY BUT STILL ANY TESTED SOLUTION HELP PLZZZZZZZZ
HERE IS MXKEY FLASHING LOG
Version from phone: 032.010
Version from file: 032.010
Using device: AdvanceBox Turbo Flasher
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\RPL\BB5_35375704799041_BACK.rpl).
RAP Data :
SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1]
EM0 ID: 00000C35
EM1 ID: 00000C30
PUBLIC ID: 0C100113D59403448C3E8C5CEE621710BD5D24F2
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
 SecondaryBoot: RAPUv11_2nd.fg [BB5]  version: 9.50.0 revision: 3.0 size: 0x3A40
 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
TransmissionMode: DDR&TX2
FlashID0: 0020 0040  - 0000 0031 [ST  NAND KAT00F00RA] type: NOR,RAP
FlashID1: 0000 0001  - 0000 0000 [unused/removed] type: NOR,RAP
FlashID2: 0020 0040  - 0000 0031 [ST  NAND KAT00F00RA] type: MuxOneNAND,RAP
 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6]  version: 9.50.0 revision: 3.0 size: 0x7F29B
RAP PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
Processing file: rm645_032.010_prd.core.fpsx as MCU
 [BB5,XSR 1.6]  size: 90.95 MB
 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 170.06 MB
CMT MuxOneNAND area [00020000-0003FFFF]
CMT MuxOneNAND area [00060000-004DFFFF]
CMT MuxOneNAND area [008E0000-0AE3FFFF]
Format Partition ...
Flash programming ...
CMT PAPUBKEYS: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 (RAP Certificate v1 249) written.
Programming completed in 1 min 3.640 s
Processing file: rm645_032.010_21.01_India_prd.rofs2.fpsx as PPM
 [BB5,XSR 1.6]  size: 30.27 MB
Erase size: 51.00 MB
CMT MuxOneNAND area [06D40000-0A03FFFF]
Programming completed in 21.172 s
Processing file: rm645_032.010_C00.01_DEFAULT_prd.rofs3.fpsx as PPM
 [BB5,XSR 1.6]  size: 7.94 KB
Erase size: 14.00 MB
CMT MuxOneNAND area [0A040000-0AE3FFFF]
Programming completed in 0.109 s
Processing file: rm645_032.010_U000.000_prd.uda.fpsx as CNT
 [BB5,XSR 1.6]  size: 1.76 MB
Erase size: 72.00 MB
CMT MuxOneNAND area [0AE40000-0F63FFFF]
Programming completed in 1.735 s
Processing file: rm645_ENO_v_0.NCP17_APEONLY.fpsx as CNT
 [BB5,XSR 1.6]  size: 2.35 MB
Erase size: 4.00 MB
CMT MuxOneNAND area [004E0000-008DFFFF]
Programming completed in 1.734 s
Flashing completed in 2 min 49.953 s
After Flash Processing ...
Phone Type: RM-645 (Nokia C5-00)
SW Version: V ICPR82_10w18.5.2 16-07-10 RM-645 (c) Nokia
Imei plain: 3537*********
Product Code: 0592662
ApeCoreSw: 032.010
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353757*******
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 4 min 36.781 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 6.968 s
Old 09-24-2010, 17:42   #2 (permalink)
Member: 302596
Thanks Meter: 784
Flash you phone with image file only with other version not the same with the MCU version..
Post result
Old 09-24-2010, 20:08   #3 (permalink)
Member: 1083123
Sonork: 100.1594766
Thanks Meter: 567
The Following User Says Thank You to monu_bd123 For This Useful Post:
Old 09-26-2010, 07:32   #4 (permalink)
Member: 613242
Sonork: 100.1626311
Thanks Meter: 645
Arrow thx mr.MONU
my problem is solve after re hot combo ic lot of thx bro
The Following 2 Users Say Thank You to jakkarzoya_2511 For This Useful Post:
Old 10-07-2010, 13:01   #5 (permalink)
Member: 384098
Thanks Meter: 33
thanks for the info , i has repair 1 set by rehot the cpu
Old 11-13-2010, 16:22   #6 (permalink)
Member: 17720
Thanks Meter: 34
yes , perfecty working , thanks
Old 01-04-2011, 10:52   #7 (permalink)
irfan_shahzad's Avatar
Member: 630431
Sonork: 100.1612755
Thanks Meter: 99
My problem is solve after re hot this ic lot of thanks bro
Old 01-06-2013, 16:43   #8 (permalink)
Ali Ahammad's Avatar
Member: 1350057
Sonork: Not use
Thanks Meter: 36
Nice Solutions
Try 1 is done
Great
Old 01-07-2013, 08:44   #9 (permalink)
Member: 1864333
Sonork: 3453
Nice Solutions .Flash you phone with image file only with other version not the same with the MCU version
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.44417 seconds with 9 queries
