01-24-2015, 04:23 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1759693 Status: Offline Thanks Meter: 54 | Nokia 110 write flash failed. Need help?? Number of Image Files: 3 Processing Image File : rm827__03.51.mcusw Processing Image File : rm827__03.51.ppm_m4 Processing Image File : rm827__03.51.image_m4_059N407 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12001010A0141834 Original Product Code: 059N407 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\353274056509684\3532740565096 84_90232.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\353274056509684\3532740565096 84_CERTIFICATE_A28AD0BC.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\353274056509684\3532740565096 84_PMM_PROT_C4AD13E6.bin Security Code: 12345 Data Sections : 04 Current File : rm827__03.51.mcusw Compile Name: rm827__03.51.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 27266440 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 43E7 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A82 Uploading Data Blocks to phone... ERROR: Write Flash Failed Can Anyone can help me to solve this problem. |
