01-19-2006, 12:29 | #1 (permalink) |
Junior Member Join Date: Nov 2005
Member: 201111 Status: Offline Thanks Meter: 0 | nokia 6600 Repairing i'm new here! when i tried to activate the Bluetooth on my 6600 phone it gives me "Unable to Perform the Operation" i also tried *#7370# but the problem is still rolling! i also have a Master and Slave PowerFlasher box (SaraSoft) but when i Click the Connect button it gives a "Can't boot UFS" error Please some body help me with this! Regards |
01-20-2006, 14:01 | #5 (permalink) |
Freak Poster Join Date: May 2005 Age: 48
Member: 142994 Status: Offline Thanks Meter: 66 | try to heat da blue tooth module..back side in pcb covered with steel net...it will work...but b carefull if give more heat...may b UEM can damaged in front hope this can help...worked many times for me don forget to post here result...... |
how to repair this nokia 6600 ? | gsmsikar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 11-17-2009 18:20 |
how to repair this nokia 6600 ? | gsmsikar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 11-17-2009 12:38 |
Nokia 6600 Destroyed Power Switch & Speaker PAD Repair <<Solution>> | CyberoptiK | Nokia Repair Guide and FAQ | 73 | 08-24-2009 12:37 |
nokia 6600 slide some repair trick, | gsmshare | Nokia Hardware & Hardware Repair | 0 | 05-02-2009 09:59 |
Repairing an Nokia 6600 | discovery | Nokia Hardware & Hardware Repair | 5 | 10-16-2008 21:03 |
