05-10-2009, 09:24 | #1 (permalink) |
Junior Member Join Date: Jun 2007
Member: 520724 Status: Offline Thanks Meter: 349 | 165o Power off after 20 seconds is there any solutions can any body help me in this problem |
05-10-2009, 09:29 | #3 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | Quote:
Rashid Ahmed Nadeem | |
05-10-2009, 10:05 | #5 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
imei corrupted .................................................. ............. | |
05-10-2009, 11:24 | #8 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | Quote:
but if ur imei is ok than ur uem is faulty..then u have to change uem ..... u can change uem from any dead phone like nokia 1200,1208,1209 & 1650.. u can change uem from these phones because in these phone uem is not glued and it can be easily changed...... after changing uem u have to make ask and get rpl from server like mx logger or ask to rpl server then u write rpl and ur set will ok.... | |
The Following User Says Thank You to digitized For This Useful Post: |
04-18-2010, 07:21 | #9 (permalink) |
Freak Poster Join Date: Jan 2007 Location: ALGERIA
Member: 431529 Status: Offline Thanks Meter: 18 | same problem 1209 RH-105 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008CE358A3BDA66 ASIC type: 11 UEM Imei: 35825003613271 Flash Imei: 35825003613271 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35825003613271_BA CK.rpl" Processing file: rh105_05.910 as MCU [DCT4,DCT4 ALGORITHM] size: 2.28 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008CE358:2984DA60 Area [01000000-0100FFFF] erased in 0.469 s Area [01010000-013AFFFF] erased in 25.859 s Area [013B0000-013EFFFF] erased in 1.704 s Area [017C0000-017EFFFF] erased in 0.125 s Area [01FC0000-01FEFFFF] erased in 0.140 s Flash programming ... Programming completed in 20.532 s File Processed in 57.282 s Processing file: rh1050_nai5.91ae as CNT [DCT4,DCT4 ALGORITHM] size: 118.39 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008CE358:2984DA60 Area [01380000-013AFFFF] erased in 1.343 s Flash programming ... Programming completed in 1.125 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.078 s File Processed in 17.593 s Processing file: rh105_05.91ae as PPM [DCT4,DCT4 ALGORITHM] size: 1.10 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008CE358:2984DA60 Area [01240000-0124FFFF] erased in 0.485 s Area [01250000-0137FFFF] erased in 8.500 s Flash programming ... Programming completed in 10.015 s File Processed in 27.500 s Flashing completed in 2 min 33.937 s After Flash Processing ... Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. PhoneType:RH-105 SwVersion: V 5.91 27-03-09 RH-105 (c) NMP MCU file: rh105_05.910 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008CE358:2984DA60 Area [01000000-0101FFFF] erased in 0.906 s Area [01160000-0117FFFF] erased in 0.891 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 23.937 s Phone Type: RH-105 SW Version: V 5.91 27-03-09 RH-105 (c) NMP Imei plain: 35825003613271-9 Product Code: 0549895 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: AE Language Pack: - not available. Imei net: 35825003613271 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 7.391 s |
CM 6280 power off after 20-30 seconds | Freshbol | Infinity-Box | 1 | 05-11-2007 09:32 |
W300 power off after 20 seconds.... | enrocas | Cruiser Suite | 1 | 08-20-2006 20:31 |
Nokia 7210 power off after 20 seconds | mohmohsah | Nokia Hardware & Hardware Repair | 5 | 05-26-2005 14:06 |
Ericsson t65 allways power on - power off after 1 second- on - off - on - off | oleg192 | Sony Ericsson Hardware Repair | 5 | 06-24-2003 16:38 |
Ericsson t65 allways power on - power off after 1 second- on - off - on - off - on | oleg192 | Sony Ericsson | 8 | 06-06-2003 03:38 |
