11-06-2011, 19:19 | #4 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Romania Age: 35
Member: 295112 Status: Offline Thanks Meter: 31 | Check the continuity between the SEND key and the END key to the LEFT or RIGHT keys, maybe a discontinued route, because this keys are on the same route. If the route is ok, then remove the keypad IC and check with your multimeter both routes from the SEND and END keys. If this two routes are ok, than try to rehot the RAP. Good luck! |
nokia6030 restarts on battery signal | unlock_solution | Nokia Hardware & Hardware Repair | 4 | 09-21-2011 17:32 |
nokia6030 | chalia | Nokia Hardware & Hardware Repair | 3 | 07-19-2009 19:51 |
nokia6030 | chalia | Nokia Hardware & Hardware Repair | 4 | 07-18-2009 18:48 |
nokia6030 | chalia | Nokia Hardware & Hardware Repair | 2 | 06-10-2009 19:28 |
what data cable 4 nokia6030 to use in mobimb | grapher | Nokia Multimedia | 2 | 01-17-2006 16:16 |
