01-28-2004, 00:53 | #1 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | nokias 3310 first when in try turn on it flash the leds, but nothing else, the other does not do anything can anyone help??? thx in advance? |
01-28-2004, 19:34 | #3 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Read the old posts , try some solutions ,specially those related to the volts. That if U allready checks all the software rulles , If still have problems post the resulted detailes. GoodLuck Br |
01-29-2004, 21:57 | #4 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @kiriazy @Rod Try to follow the service manual, and check the following values : 1 : VB 3.6 V at C227/228 2 : 32.768 KHz at C220 (in my exsperince it does not matter if theres some noise at the edges of the sqaure wave, as long the freq. is ok) 3 : PWRNX at R402 is 3.6 V and drops to 0V during Press of PWR swicth 4 : VBB 2.8 V at C209/211 5 : Vxo 2.8 V at C243 6 : Vcore 1.7 V at L200 at both pads 7 : SLEEPX 2.8 V at J308 8 : PURX 2.8 V at R308 after PWR press 9 : 13 MHz at C303 Do please check all above and report back if some values are not ok. Regards |
01-29-2004, 22:36 | #7 (permalink) |
Member: 7751 Status: Offline Thanks Meter: 74 | @Rod Go to the section called Schematics/layout, and you will find those components, these components are mostly around CCONT, not too hard to find. Regards |
01-30-2004, 09:34 | #12 (permalink) |
Freak Poster Join Date: May 2001 Location: Baia Mare, Romania
Member: 4758 Status: Offline Thanks Meter: 5 | yesterday with a 3410, the rssi without card was constantly at 112-113dB, but with card starts with full signal, then 3lines, 2lines, 1line, then no netw, after 10 seconds signal commes full again, but trying to call only single short burst Tx, i changed everything: ccont cobba hagar duplexer PFO the loop between PFO&duplexer, all electrolythic capacitors all filters in 900band, but the same. and finaly i solved the thing by changing RTC Quartz at ccont.... so that meens maybe was noisy. the rtc was correct meening the clock. bye, felix. |
02-02-2004, 18:12 | #13 (permalink) | |
Junior Member Join Date: Oct 2003
Member: 41429 Status: Offline Thanks Meter: 0 | sorry Quote:
Thanks very much. | |
Is it the on/off switch is same in between nokia 6600 and nokia 3310 | yccomc | Nokia Hardware & Hardware Repair | 2 | 09-30-2005 03:33 |
Wanted x1 nokia 3310 board & x1 nokia 3410 board | cameraman | Wanted Products | 4 | 09-12-2004 16:11 |
NOKIA 3310 | AMTX99 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-26-2001 17:01 |
There it is ! The new Nokia 3310 | Tevoxx | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-01-2000 13:44 |
NOKIA 3310 | Tevoxx | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-31-2000 14:05 |
