01-16-2007, 22:38 | #7 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | first thing is to try with new keypad board (the part with white dome sheet stuck on it). you can peel back the dome sheet and clean with toothbrush and cleaning solution if there is sign of oxidation. other than this then you can try to replace the two ESD filters as said above. very easy to replace, just need good heat and flow, gel flux, small tweezers and steady hands! |
01-18-2007, 10:08 | #8 (permalink) |
Freak Poster Join Date: May 2006
Member: 283474 Status: Offline Thanks Meter: 41 | Thank u all for your advice, but u all knows that d legs are led with too hot it met &n bridge together which makes it difficult to fix, can u say d level of d heat to be apply on d ic please. |
Repair all 6230 key problems | thecult | Nokia Hardware & Hardware Repair | 9 | 01-01-2007 16:17 |
6230 Key problem! Pads broken ! | stadik | Nokia Hardware & Hardware Repair | 0 | 01-17-2006 21:05 |
Nokia 6230 Keys Problem | adeel786 | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 12-29-2005 16:27 |
6230 keys problem | HUM | Nokia Hardware & Hardware Repair | 2 | 08-23-2005 01:42 |
6230 key problem | historik | Nokia Hardware & Hardware Repair | 1 | 09-02-2004 16:23 |
