Old 03-16-2006, 20:26   #1 (permalink)
Member: 30140
Thanks Meter: 17
2300_1100 NEW R100 Location
R100 New Location is left side flash IC under 2 capaciter see picture below
Old 03-19-2006, 22:03   #2 (permalink)
GAZZUZZ's Avatar
Member: 205128
Thanks Meter: 18
What Does It Do ??? Whats The Use Of The R100 Resistor
Old 03-21-2006, 10:35   #3 (permalink)
Member: 30140
Thanks Meter: 17
For repair charging problem
If phone show "Not charging " or not start to charge after connect charger if fuse not open
Old 03-21-2006, 10:49   #4 (permalink)
zakariababu's Avatar
Member: 67233
Thanks Meter: 20
This resister open charge normal?
Thanks
Old 03-23-2006, 10:17   #5 (permalink)
Member: 248086
Thanks Meter: 22
boss may tanggap ako na 6600. pag connect mo sa cable lumabas naman yong nokia pero after 3 seconds nad di dis appear din. dalawang besis ko nang in flash ganun parin. plss help me.???
b.r.
Old 03-23-2006, 14:38   #6 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
write in english
bro
Old 03-23-2006, 15:12   #7 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
@rajiv007,
elvislano is phillipines and he write in tenglish. teglong +english.. they use it freely in pinoy forum. [ like it hinglish ]
wbr
Old 03-24-2006, 10:47   #8 (permalink)
Member: 248086
Thanks Meter: 22
boss can i see the whole diagram of k500 mostly in joystik parts>?
thanks.
elvislano
b.r.
Old 03-24-2006, 10:50   #9 (permalink)
Member: 248086
Thanks Meter: 22
boss can i see the diagram of k500 most especially in joystik parts.?
thanks
elvislano
Old 03-24-2006, 12:06   #10 (permalink)
Member: 15593
Thanks Meter: 19
1100 not charging
Hello ASK_ME,
i have one phone with not charging must i replace R100 from a Nokia 3310?
If i want to test this resistor how much OHM must displayed my Digital Multimeter?
Sorry for my bad english.
noko
Old 03-24-2006, 13:18   #11 (permalink)
Member: 30140
Thanks Meter: 17
R100 value
Original R100 is thermister (resistance depend on temperature)
At my room temp about 30 C .Meter show 31 Kohm.
If you use R from 3310 ,Meter must show 47 Kohm.
Old 03-24-2006, 13:36   #12 (permalink)
Member: 15593
Thanks Meter: 19
R100 from Nokia 3310
Hello ASK_ME,
have you a better picture from this resistor on the Nokia 3310 board? I cant located it correct. Please help
noko
Old 03-24-2006, 13:50   #13 (permalink)
Member: 30140
Thanks Meter: 17
Hi elvislano
See picture may help you
Old 03-24-2006, 15:03   #14 (permalink)
Member: 247433
Thanks Meter: 25
Good solution bro
Thx a lot
Old 03-27-2006, 15:08   #15 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
when i try to check the R100 in-circuit in a 1100 , it is showing 8K ohmz , is that Ok or not ?
and how to check it in-circuit?
please help..
thanks
reg file location in vygis website help am new ARAB GSM VygisToolbox 1 04-14-2008 20:55
reg file location in vygis website help am new ARAB GSM VygisToolbox 1 04-14-2008 20:28
R100 47k 1100 - R100 47k x2 3310 sevgigsm Nokia Hardware & Hardware Repair 1 05-05-2005 08:40
Where is A800 eeprom ic located?where the located? External hooi76 VLSI, Conexant, Skyworks and Old Models 2 03-03-2005 14:47
Page generated in 0.21755 seconds with 10 queries
