Old 11-19-2001, 20:35   #1 (permalink)
Crazy Poster
Member: 7242
Post Over drove nokia - "no signal"
My friend accidently ran over his nokia with his car and he gave the phone to me and i have fixed all stuff on it so it works. But i dont have a signal. I have new antenna and new housing. Any suggestions of what might be wrong?
Old 11-20-2001, 03:01   #2 (permalink)
Bert's Avatar
Member: 596
Sonork: 100.33096
Thanks Meter: 514
Post
Hello <br />It's simple bad contact for the rf part componet, you just need to use the hot air gun to reflow that.
Old 11-20-2001, 11:49   #3 (permalink)
Crazy Poster
Member: 7242
Post
Shall i reflow cobba? Or is it another stuff i shall reflow?
Old 11-20-2001, 22:11   #4 (permalink)
Member: 7062
Thanks Meter: 126
hi., <br />chek the antenna part may b broke then clean the pcb well specially the rf module section o.k heat and reflow the haggar... fdk .. vco..and the pf and chek with a microscoap the antenna switch ... may b it works <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0">
Old 11-21-2001, 00:41   #5 (permalink)
Crazy Poster
Member: 7242
Post
Ok. I tryed hotairflow on cobba and it didnt work. Going to check the other stuff on school tomorrow. Hope it works.
Old 11-21-2001, 16:12   #6 (permalink)
Crazy Poster
Member: 7242
Post
I tryed to reflow cobba and the other components and i get a signal for about 5 sec and after that i disapere completly and i have tryed to reflow it about 6times and 3times i got an signal but it disapere.
Old 11-21-2001, 17:55   #7 (permalink)
Member: 7327
Thanks Meter: 12
Post
hello m8
change the rx filters & ull get signal 10000% it happend to me with a 8210 , & now working ok .
& if the signal comes on & then go , change the<br />P.A. & all will be ok .
kind regards .
<FONT COLOR="#ffff00" SIZE="1">[ 21 November 2001 18:02: Message edited by: digi_com ]</font>
Old 11-21-2001, 20:45   #8 (permalink)
sat
Member: 5764
Thanks Meter: 2
Post
I got problem on 3210, that has signal coming and going out continiously. I reflowed COBBA, changed VCO's, PA's, 13 mHz, 71 mHz, other little filters, still no joy. What else can be done?
Old 11-21-2001, 21:50   #9 (permalink)
Crazy Poster
Member: 7242
Post
Thankz. I going to try that tomorrow on school. I got an 5110 today with same problem.
Old 11-21-2001, 22:00   #10 (permalink)
Crazy Poster
Member: 7242
Post
Damit. Not sure if this is the components i shall change:
<a href="http://www.inside-gsm.com/Nokia/Nokia_3310/Inside_Nokia_3310/Component_side_description_Nok/component_side_description_nok.html" target="_blank">http://www.inside-gsm.com/Nokia/Nokia_3310/Inside_Nokia_3310/Component_side_description_Nok/component_side_description_nok.html</a>
3 and 5 on this picture? It is the "5. Hitachi PF08109BN dual frequency PA" and "3. Diplexer (RXTX switch)"
Old 11-21-2001, 22:31   #11 (permalink)
Member: 7327
Thanks Meter: 12
hello m8
look try to measure the voltages found in the service manual first to know if the hager bga is ok, if the voltages r ok , then start by changing the component no 2 i think it will work for u , if u got no signal , then change the pa no 5 ,<br />if it didnt work , then try to make manual search<br />if u got a signal & then gone , then change the <br />Diplexer (RXTX switch) .
i think this is a brief description .
hope this can help .
kind regards .
Old 11-22-2001, 00:45   #12 (permalink)
Crazy Poster
Member: 7242
Post
Thankz m8. I have the service manual going to print it out then.
Old 11-27-2001, 02:54   #13 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
Post
I have a 3310 that signal come and goes!
I changed Diplexer,PA,SAW filter,<br />still no result!
any help?
6300 nokia "no acess" msantar Nokia Hardware & Hardware Repair 2 07-14-2008 14:43
help me Nokia 6300 "no signal" anstar Nokia Base Band 5 ( BB-5 ) 1 05-25-2008 09:27
need help for 6800a "no signal" jaycoy Nokia Digital Core Technology 4 ( DCT-4 ) 1 08-09-2006 14:32
9300 "No signal" After DCT4Direct likwidsky Dct4Direct 4 08-29-2005 12:18
help me t191 "no signal" ali25 Motorola Hardware Repair 0 10-05-2004 22:02
Page generated in 0.19288 seconds with 9 queries
