Old 08-16-2003, 22:50   #1 (permalink)
Registered User
Member: 8527
Thanks Meter: 11
3510 no ringer but vibra is OK
I have one 3510 dropped in water. I've cleaned the PCB and now the phone is OK except the ringer wich doesn't work at all. I tried with another ringer but it's the same. Also the LEDs don't light as they should.
Is there an UI chip like in the 3310?
How can I repair the phone?
thanks
Old 08-17-2003, 20:42   #2 (permalink)
Member: 13545
Thanks Meter: 2
First try flash the phone .....
MrHazeem
Old 08-18-2003, 17:09   #3 (permalink)
MPhoneClinic's Avatar
Member: 20639
Thanks Meter: 233
and check the curcuirt lines for the LED and ringer.. there is no UI like 3310... and check NSC 1w for ringer.. NSC: nationa semi conductor, just pull it out , clean it.. it works to me most of the time..
regards
TMPC
Old 04-07-2004, 18:57   #4 (permalink)
cellcity's Avatar
Member: 58052
Thanks Meter: 21
if u find solution pls let me know i have same problem thanx len
Old 04-07-2004, 21:05   #5 (permalink)
Member: 44658
most probably the phone is BER.
try to flash it.
Old 04-07-2004, 21:09   #6 (permalink)
Registered User
Member: 8527
Thanks Meter: 11
Didn't work for me...
The phone has been returned to the customer.
M600 no ringer nor vibra !!!! tattoum Samsung Hardware Repair 5 04-17-2009 23:08
v980 not flash, not leav blank mode, no display but phone is on and other is ok tkowsar Ultima Box Light 8 08-04-2007 11:31
6230i: no buzzer sound but handfree is OK PSG Nokia Hardware & Hardware Repair 1 05-29-2007 10:11
S200 no ring but sound is OK barvik Samsung Hardware Repair 1 10-21-2004 06:01
3210 and no sound ... but buzzer is OK siewa26 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 09-05-2004 09:30
Page generated in 0.20077 seconds with 9 queries
